Fluttering whistle, please help, video of noise included
My Ride: 2008 535i
This fluttering whistle is driving me mad. Listen to the video to share in my madness. It's louder and more pronounced than what is captured on the video. I would greatly appreciate some insight if anyone has experienced this annoyance themself.
Facts
2008 BMW 535i
It's only audible under about 25% throttle at low speeds.
Lighter or heavier throttle does not produce noise.
Noise doesn't change pitch, only volume depending on throttle application.
It takes about 20 mins from cold start before noise occurs, immediately upon warm start.
Can be heard momentarily when revving from idle (1500-2000 rpm).
Seems loudest from driver seat up near dash, not audible outside vehicle with the hood open when revving from idle.
No perceived effect on performance.
No CEL.
Hypothesis
Cracked or broken plastic elbow or tube. It may take a little heat soak before expanding and creating a whistling orifice. Thus far unable to locate any split parts.
It is not turbo whine, I know that sound. Haven't yet ruled out the blow-off valve or wastegate.
Background
I am a competent mechanic. I have a lot of experience with turbocharged cars and worked for years as a technician on a racing team building engines and chassis.
Thank you for reading, and thanks in advance for your insight. It's probably something simple but worried it's something expensive. In either case, it's driving me mad!
Facts
2008 BMW 535i
No CEL.
Hypothesis
Background
My Ride: 2006 BMW 550i
My Ride: 08 535i Sport
Bypass/recirculating valves maybe?, I've heard that sound on audi's and vw's that use the same Bosch designed style valves. Remove them and check for ripped diaphragms or weak main valves.
My Ride: 2008 535i
Here's another video. Still faint, but audible, so crank the speakers. I promise that this is far more pronounced and irritating than the poor audio quality suggests
you say you hear the noise by dash, but not outside? do these cars use engine vaccum to control the heater controls and flaps? have you tried turning the hvac completly off?
Probation Members
My Ride: 2015 535i
Did you ever figure out what was causing this noise? My 2015 535i is making the same noise. I'm hesitant to take it to the mechanic without knowing a possible cause. I do have a video, but the noise is faint.
turbogate
04-11-2015 05:02 PM
