Fluid on my drive way. Oil or Transmission Fluid is the Question?
My Ride: * 2010 BMW 528i M Sport
* 2010 BMW X5 M Blue
* 2004 BMW 530i Sport, Silver Gray
* 2004 BMW 530i Sport, Black Sapphire, Auburn Dakota Leather.
* 2006 530I Monaco Blue / Grey, M-Tech Front and M5 rear bumper and side skirts. M5 lip spoiler. M5 166M wheels.
Hello,
I recently purchased E60 530i Sport with only 30k miles. I assumed the dealer changed the oil prior vehicle delivery. My iDive System indicates 14k miles to next the oil change. I noticed some fluid patches on the my drive way. I am trying to understand if the spots are from engine oil, transmission fluid or some other fluid?? I checked my engine oil level. It?s little bit over the max mark. I don?t like this at all.
I have been keeping eye on the oil level and it does not seems that I am loosing any engine oil. The plastic cover under need the car has some wet spots somewhere between the passenger seat and engine compartment. Hard to tell exact spot / source of the leak. Now my concern is the transmission fluid, which I am not sure how to check. How difficult is to differentiate the engine oil from the BMW transmission fluid?
Any comment / advice are greatly appreciated.
Thanks,
Vince
Thanks,
Vince
It's not that hard.
Motor oil is VERY black. Transmision fluid is lighter and tinted like red or green etc.
You also have power steering fluid and anti-freeze.
The best thing is get under there and check out any wet areas.
My Ride: '06 530i M Sport N52
get it on a ramp and get the undertray off and you'll know what it is. the location says tranny fluid to me, had it on 2 different e60s. the sump under the gearbox cracks easy, made of egg boxes.
Confirmed:
The fluid is actually transmission fluid.
Hello,
Thanks,
Vince
Thanks,
Vince
how easy is it to replace that seal/ sleve cuz im leaking lil spots on my driveway and like you guys am having a hard time telling if it is oil or tranny fluid,
another thing is that the drip only happens while the car is running, if I turn car off the drip dries up, what color should the fluid be if it was transmission fluid that is coming out?
