"Flat Tire" error message when there is no flat tire
Old 11-01-2010, 03:42 PM
code37's Avatar
How do you get rid of the "Flat Tire" message? I'm driving and suddenly the warning appeared.
I checked the tires and they are fine, i even checked the tire pressure & provided a little additional air.
Its been 5 days.
How do you remove the message? thanks
Old 11-01-2010, 03:48 PM
acuteperformance's Avatar
My Ride: 14 550i
Go into your iDrive settings and select FTM/TPMS and reset it
Old 11-01-2010, 03:53 PM
Gene's Avatar
+1..and you will need to drive for a bit before the actual sensors reset, staying parked and just trying to reset via iDrive will not reset the sensors...
Old 11-01-2010, 04:03 PM
toyota2bmw's Avatar
Its been 5 days.
You get the warning even if you have just one of the tires low on air. Make sure you set all the tires to proper and even pressure per OEM spec and do a reset in the i-drive.
Old 11-01-2010, 04:12 PM
Hyper_545i's Avatar
My Ride: 545i
Engine: N62
All good advice! Inflate all tires to spec. and reset your TPMS/FTM. If the issue returns, you may have a cracked rim. At least thats what happened in my case.
Old 11-01-2010, 05:10 PM
Kaizen's Avatar
My Ride: 2005 545i Alpine White Premium package, Sport package, Nav, HUD, PDC
+1 I had the same issue. It was slow leak at first and I had to fill with air and reset idrive every 2-3 days. It got bad enough where I'd have to fill in air daily.
Old 11-02-2010, 01:14 AM
JAY'545's Avatar
If u have a slow leak the cold weather will make it leak even worse. Meaning maybe once a day or so.
Old 11-02-2010, 04:11 AM
damian's Avatar
My Ride: 545i
Old 11-02-2010, 11:06 AM
code37's Avatar
you guys rock! could it also be from the tire becoming deformed due to colliding with a curb, going over a solid object or bump on the roadway?
But you guys hit it right on the spot in regards to clearing the message . I probably should get it check for deformation, leakage, flat, or even a nail stuck in there...... Thanks again!
Old 11-03-2010, 10:06 AM
bigbadbull's Avatar
My Ride: 2010 VW Passat Wagon 2.0l Tsi Grey/Grey Budapest 18" Lost to HPFP issues: 08 535i sport pkg Lost to Dreaded E61 Sun roof leaks: 07 E61 530Xi
What year is your car? The TPMS uses air pressure vs the TPM using wheel rotation monitored by the cars ABS on the 06 and older cars. If you curbed it bad I could see the ABS based system reading a flat.
Quick Reply: "Flat Tire" error message when there is no flat tire
