Flashing auto headlight switch
Old Aug 23, 2011 | 04:17 PM
Shlooky's Avatar
My Ride: 545i
no wires were loosened. I simply removed the after Market stuff and put back the original and everything worked again. I even tested it one at a time, so I replaced the one side with the original and AHL worked. but the other didn't, then I replaced the second and all was ok.
One day I will attempt to reinstall the after market lights to see if AHL disables itself. Probably on the weekend.
Old Aug 23, 2011 | 04:37 PM
norsecarnut's Avatar
My Ride: 2008 535xiT6
auto lights are stupid, you might as well get on a bus or train.
Old Dec 17, 2013 | 06:38 AM
BraveHelios's Avatar
My Ride: 2004 545 6 M/T
2004 545i with AHL.
Has anyone ever heard of the LED flashing light by the headlight switch BECAUSE the fog light bulbs were replaced with different wattage (80 vs 51) or anything else concerning the fog lights?
My LED just stated flashing... although I cannot recall if it started flashing when I replaced the fog light bulbs.
Thanks!
Old Dec 17, 2013 | 12:47 PM
jdmek998's Avatar
No it shoulnt be. They turn on differently.
Old Dec 18, 2013 | 08:22 AM
Okay... so would it be co-incidental that I just had my car in to change out the water pump and assorted coolant hoses and it seems that the issue started the day I got my car back? I need evidence!
Old Mar 1, 2014 | 04:48 PM
shadi's Avatar
My Ride: bmw 530i 2004
Hi guys the green led inmy light switch is blinking i noticed that the lights on automatic are not adapting the way i steer , but it turns on when am in tunel or when it gets dark but not going left or right its stable . Whats the probleem pllzzz help
Old Jun 8, 2015 | 01:44 PM
normhaas's Avatar
My Ride: 2005 545i
Default Got the blinking AHL light after putting in after-market halos too.
Changed the halo's and got the blinking light. I was so proud of myself. Hate to have to put the originals back in. The headlights still level, so it's not the motors. The maker of the halo's said that the BMW system would recognize them. False advertising? Is there a way to make the work without taking them out and replacing the originals? LED's look so much better.
2005 545i - Oriental Blue
justalilbit
Apr 28, 2015 05:36 PM
555
May 21, 2004 06:46 PM
sg520i
Mar 31, 2004 12:02 PM
Guest_Tony
Dec 11, 2003 01:35 AM
