Fixed onboard Errors
My Ride: 2007 ★ Alpine White
I am sure there is topics somewhere on here about this. I was getting all kinds of errors. There was nothing wrong with the car as far as driving it. I was getting Transmission, Tilt shift, DBC, Drive Control system, and Start of assistance errors on my monitor. I consulted with one guy who thinks it might of been then Crankshaft positioning sensor or alternator, or even the Battery. Got the battery tested but they couldn't test the alternator because of low Volts. To make sure what it was, I took it to BMW for a diagnostic test ($99) and thorough look over. Low and behold it was what we thought it was. It was the Crankshaft positioning sensor which had to be replaced which they wanted $1000+ for parts and labor. The part cost $145 OEM through Dealer or $98 if you got a friend who can get it for you. I took it to an Indi and had the labor done for $150. He cleared out all the errors and car is back on the road with no errors.
Besides that the dealer told me I had a little leak with the bushings which they wanted $1200+ for parts and labor to replace the bushings and control arms. I will take care of this after vacation.
My Ride: 09 550i 6sp M-Tech. 18mm spacers rear, 8mm front. Dinan intake and Stage 2 tune. Tinted tails, M5 OEM lip spoiler.
08 Z4 3.0si Black on Black with Beige top. Removable hardtop. (Hers)
06 Volvo S60R Heavily Modded!! Gone and missed.
Damm, good delta on the indy price there.
Leak with what bushings??
R&I INTAKE MANIFOLD, REPLACED THE
CRANKSHAFT POSITION SENSOR AND CLEAR
FAULTS + DIAG. (CRANKSHAFT POSITION SENSOR
MALFUNCTIONING. CAUSING TRANSMISSION
WARNING AND DSC WARNING.)
$1,015.00
Replace both front complete thrust rods
with bushings (aluminum) (both front
thrust rods split and leaking fluid.)
$1,298.88
This is off the BMW of San Diego Recommended Action Plan after getting my car inspected
$1,015.00
$1,298.88
What model do you have? I've been all through the realoem.com parts diagrams and cant find any "Thrust Rod" anywhere? I was asuming something with the front suspension since you said bushings.
