First real problem, AC fan
I took my car in for a AC problem this morning.
The fan sometimes works and sometimes not.
It does work in auto mode and it cannot either be controlled manually.
It blows air but with some pre-adjusted and low setting
The car has been the whole day at the BMW service garage and they have changed
the fan motor, the fan regulator and the sensors, but nothing did fix it.
Must add that the problem was there with CIP 19.2 and still is there with CIP 24.2
So now the car will be at the service untill...
But it's fun to drive a small free loaner (116i) with stick-shift and spike winter
tyres on super icy roads, lot's of fun, actually
![Wacko](https://5series.net/forums/images/smilies/imported/wacko.gif)
My Ride: 2006 525Xi Build: Sep 2005 Del: May 2006
Ti Silver | Black | Premium Pkg. | Cold Weath. | Step | Xenon Adapt.
Too bad, but at least you are having fun with the loaner. It sounds like it should be simple to fix, but it isn't a good sign the first attempt didn't solve it. Good luck!
Update, problem solved!
They replaced the fan motor and the regulator yesterday,
but only today they realized that with the new parts a new
programming was also needed
Now the AC and fan works perfect again.
They washed the car inside and outside + the engine for free,
as an excuse.
I'm very satsified with my BMW Service
as an excuse.
I think by now we should just assume a software issue after the obvious hardware issues are fixed!
Awest91
09-17-2022 11:05 PM
DavaiLave
08-02-2022 02:16 AM
UltimatePeter
DIY: Do It Yourself
05-12-2015 08:00 AM
carid
04-29-2015 04:20 AM
