fault code decrypting
i have numerous fault codes on my car but cannot work them out ,inpa loves its german and always gives me a language mismatch
i need help to work out what they are . alot are from the heating system
1 is from the dde i think its to do with the dpf delete if so i have to take the car back to the mappers and get them to sort it but would rather go prepared
My link
My link
My link
My link
My link
My link
My link
My link
Very strange. Tried looking for those codes, no luck. Tried converting hex codes to decimal, no luck again. They seem too "high" for any lists that I've found (lists go up to 5xxx and you have 9xxx). My advice would be getting an English version of INPA (well at least one where errors are in English). Also my INPA writes a regular P-code. Anyways if you need links for the software I have, let me know.
These are BMW codes. There is no translation of a P-Code for these
OP - looked at your errors and you have a motor ventilation issue. i would check for vaccum leaks. Clear the EM and IM and inspect for vaccum leaks.
My Ride: 07 550i Sports Package
My link
My link
My link
My link
My link
My link
My link
My link
0x05619C69 9C69 Rear compartment stratification controller
0x05619C79 9C79 Water valve, left
I couldn't make out the last code from the pic you posted. I tried to attach a pdf list of hex codes but it was too big.
linxuan
E39 Discussion
03-22-2015 06:16 AM
