Faster cornering with anti-roll stabilization?
Old 08-23-2005, 01:24 AM
heezy545i's Avatar
Can you actually corner faster with anti-roll stabilization, or does it just feel like you can?
Old 08-23-2005, 01:42 AM
BetterMakeWay's Avatar
[snapback]162320[/snapback]
Good question! I suspect u're talking about dynamic drive! right?
Old 08-23-2005, 01:59 AM
heezy545i's Avatar
Yes.
dynamic drive = anti roll stabilization
Old 08-23-2005, 05:48 AM
PaulK's Avatar
I believe you can corner faster as the lack of body roll (without rock hard suspension) means that a little less weight is shifted to the outside tires and therefore the inside tires maintain more grip.
Beware, though, because other people will not realize how fast you are cornering without the usual body roll.
Old 08-23-2005, 06:41 AM
Rudy's Avatar
My Ride: G30 M550i
Model Year: 2018
I think PaulK is correct. I'm no Physicist but I have to believe that the car's weight is more evenly distributed over all four wheels when the car stays flatter in a corner with ARS. With a more even distribution, there is a larger contact patch under the inside two tires, etc.
That said, I think you'd have to be cornering mighty fast to really see much of a difference...
Old 08-23-2005, 07:23 AM
Edlee's Avatar
I've overdone it many times only to be corrected by the sight of the DSC lights coming on.
Old 08-23-2005, 07:35 AM
teutonictrio's Avatar
[snapback]162422[/snapback]
I did it in my test drive - what a great car. That's why I'm getting one...
Old 08-23-2005, 08:39 AM
kfarouki's Avatar
My Ride: 2001 Z3 3.0, Sports Package, Winter Package, 5-SpeedHard Top [built: pick up in Munich on 5.17.06] ED 2007 550i 6-speed (sapphire black/black dakota leather): sports package; active stearing, hud/nav, logic 7, cold weather package, rear heated seats, rear folding seat, power shades, comfort access, sat radio
The physics show that you should be able to turn faster [due to weight distribution as others have described]; but, there is anecdotal evidence of this as well.
I've seen numbers that show a 545 with a faster lap time at the "ring" than the E39 M5. Certainly the old M5 was a more powerful car than the 545... the common explanation for the E60 getting better times was the increased exit speeds out of the [plethora of] turns on the "ring". Makes me very excited to take my ED 550 out there.... of course I'm sure that I won't be even close to the lap times in question.
Old 08-23-2005, 08:52 AM
Originally Posted by kfarouki' date='Aug 23 2005, 09:39 AM
[quote name='heezy545i' date='Aug 23 2005, 02:24 AM']Can you actually corner faster with anti-roll stabilization, or does it just feel like you can?
[snapback]162453[/snapback]
[/quote]
Can anyone drive the ring? I plan to do ED also and how incredible would that be to drive the ring when over there!! My ED would be March, likely, so it's perhaps not possible due to SNOW!
Old 08-23-2005, 10:26 AM
jet190rs's Avatar
[/quote]
What were the 545's lap times?
Quick Reply: Faster cornering with anti-roll stabilization?
