Expert needed: Steering noise front left wheel
Old Jan 27, 2019 | 07:37 AM
jgbmw's Avatar
Default Expert needed: Steering noise front left wheel
My left front tire has wear (highs and lows) on the inner side.
I've had the inner and outer tie rods replaced and control arms were replaced a couple years back.
With the front left wheel suspended, top/bottom does not move. However, left/right moves on the right side.
Here's a video of noise when pulling wheel left to right.
https://www.dropbox.com/sh/6l5wzkloy...vCO5IuX5a?dl=0
The right side wheel does not have this play. Could this be a bad alignment or a steering rack problem? The techs said that the left shock would have to be replaced to get the wheel in alignment. ???
Old Jan 29, 2019 | 08:23 AM
GregFerd's Avatar
My Ride: e60 n54 sport auto
Model Year: 2010
Engine: N54
I vote; inner or outer tie rod end
Old Feb 11, 2019 | 06:11 PM
jgbmw's Avatar
Thanks. I had those replaced recently. I'm not sure what else should be replaced other than the steering rack which doesn't seem loose.
Old Feb 11, 2019 | 09:13 PM
seanjordan20's Avatar
Engine: 3.0 B58; 3.0 M54
Does it make the same sound in the air without the weight of the car. You need a second pair of hands. Have you removed the wheel then tried to see if it makes the noise. It seems to me it has something to do with either the outer tie rod or shock area. It's hard to tell.
Old Feb 13, 2019 | 11:18 AM
audiophool's Avatar
My Ride: 535xi
Based on the vid, looks like the steering tie rod is moving properly with the wheel but there's play at the inner joint (in the steering rack). Can you replicate the noise by steering back and forth a little bit with weight on the tires? Maybe make another video with the camera set to view the inner joint area and test per my comment.
Old Feb 13, 2019 | 08:00 PM
jgbmw's Avatar
The techs tried moving the wheels without weight of the car. They said they don't see any issues.
Old Feb 13, 2019 | 08:06 PM
jgbmw's Avatar
It does make the same noise with weight on the tires. Since the inner and outer tie rods have been replaced, I thought there's something loose in the steering rack. I was wondering if the mounts for the steering rack could be tighten?? Or the problem was in the steering rack itself.
Old Feb 14, 2019 | 07:54 AM
audiophool's Avatar
My Ride: 535xi
Can you see if the steering rack is moving on its mounts? I don't think there are bushings on this rack, just hard mounted to the subframe. At least that's true on the 535xi. If it is moving, loose bolts?
mylesfiggy
Nov 10, 2016 07:37 AM
SocalM5Lover
15
Oct 18, 2008 05:33 PM
titanic
Sep 24, 2007 07:42 PM
Lucky
Dec 31, 2005 06:14 AM
E60525d
Jul 2, 2004 01:11 AM
