Error code "AFS-6136 AL:Motor position Sensor: Fault, Sensor suppl
Old Sep 27, 2012 | 01:19 PM
panklee's Avatar
Banned
My Ride: magsmuroVE
Model Year: magsmuroVE
Engine: magsmuro
I'm getting Active Steering Mulfunction from my 2007 550i. I installed DIS v5.7 and ran on it. I'm getting error code "AFS-6136 AL:Motor position Sensor: Fault, Sensor supply --- Fault currently present. Accepted Symptoms". Is it saying that I have bad steering angle sensor or what? Where is Motor position Sensor located at? Please Help me.. I have spend 3 days to setup the DIS and I got this. Should I just go to the stealers.
Old Sep 27, 2012 | 03:02 PM
turboawd's Avatar
My Ride: 2006 BMW 550i
did you have the fault before or after you used DIS?
i want to say the steering sensor is on the power steering rack.
Old Sep 27, 2012 | 03:45 PM
panklee's Avatar
Banned
My Ride: magsmuroVE
Engine: magsmuro
I had Active Steering Malfunction sign before I used DIS. This is the reason I spend 3 days to install and figure out how to use DIS v5.7.
After using DIS v5.7, I don't know what to do after???
Old Sep 27, 2012 | 03:46 PM
panklee's Avatar
Banned
My Ride: magsmuroVE
Engine: magsmuro
Old Sep 27, 2012 | 03:47 PM
turboawd's Avatar
well dis wont fix the car for you. try reseting the fault code. if it comes back again, then you got some work to do...
Old Sep 27, 2012 | 04:47 PM
panklee's Avatar
Banned
My Ride: magsmuroVE
Engine: magsmuro
When I looked at the DIS program. It said that it cannot be deleted. I could not delete the error sign.
jo786
Apr 28, 2015 02:30 PM
shoryuken15
Apr 9, 2015 03:42 PM
Stranger12
Apr 5, 2015 10:42 AM
wrx5
Mar 29, 2015 04:53 PM
