Hello guys. Has anyone got this problem when try to connect Ista P with E60? Ista D/+ working fine connect with car but Ista P just crashing here. For info I use OEM ICOM A from BMW Dealer. I try 2/3 versions of Ista P, but I got the same error. Please help.
Do you not have an ICOM B and what SP-DATEN are you using and man that program version is old. I'm guessing you're not using an ICOM Next either. These are the things I see why you're having an issue
I using ICOM Next A Part N:81-31-2-360-883 and it's a 100 OEM from BMW Dealer. The Ista P, is downloaded from internet.
Forget to say, Ista D/+ are downloaded from internet too and it's working very well without issues.
And It's neccessery to using Icom B for programing E60 ?
ISTA P is a separate program and has almost nothing to do with ISTA+. Nothing in those 2 programs have shared files hence they are 2 different install folders. I would suggest you get an ICOM B. I would also suggest you upgrade your ISTA P to at least 3.69 preferably 3.72 and update your SP-DATEN files to v71. I'm looking at your errors and the last 2 are your program issues. The first one is the lack of ICOM B because you're trying to communicate with a module that communicates on MOST.
Thanks man. I already ordered Icom B from bmw dealer right now. I tried to connect with my E60. Now I downloaded the latest version of Ista P v3.72 and later I will say if everything is okay. One question, It is possible to programing with Ista +/D I think it same, a BMW X4 2017 year ?
