Entertainment Symbol
My Ride: '05 545i(Build 10/04)(SMG)Sport,BlkSapphire,Blk,Anthricite,Logic7,CWP,Comfort Seats,Nav,RearBags,Shades,Sirius,Heated/SplitFoldingRearSeats; '18 540i xDrive, White/Mocha, CWP, DAP, DAP+, Lux. Pkg, Prem. Pkg., Executive Pkg., Luxury Seating Pkg
Model Year: 2005,2018
This symbol appeared today on my I-Drive in the position usually used for entertainment symbols. Any ideas what it means. It remained on the screen from the time I left home and reached my destination. When I restarted my car, the symbol disappeared and the normal symbols appeared.
Any ideas.
Joe
Any ideas.
Joe
My Ride: G30 M550i
Model Year: 2018
Were you listening to Sirius when that was displayed?
I've seen that happen when the Sirius stream is interrupted like when going through a tunnel or driving in a parking garage. Basically, the receiver didn't fully receive the data showing the stream name from the satellite. What you see are "unprintable" characters or simply garbage characters. Since the data for the stream name is only sent when you change channels, it's likely that the garbage stayed there until you turned the car off if you listened to the same channel. If you would have changed channels, it would have cleared and the new channel (stream) name would have appeared...
I've seen that happen when the Sirius stream is interrupted like when going through a tunnel or driving in a parking garage.? Basically, the receiver didn't fully receive the data showing the stream name from the satellite.? What you see are "unprintable" characters or simply garbage characters.? Since the data for the stream name is only sent when you change channels, it's likely that the garbage stayed there until you turned the car off if you listened to the same channel.? If you would have changed channels, it would have cleared and the new channel (stream) name would have appeared...
[snapback]134641[/snapback]
Thanks
Joe
My Ride: Now Driving a Freakin' Prius!
Was...
2004 545i | SMG | White/Black | Sport | NAV | Logic 7 | PDC | Fold-down Seats | Adaptive Headlights | Cold Weather Pkg | Clear-again Bra | Mud Flaps | Bluetooth | Coat Hangar | Aux Input | All Weather Mats | 18"X8.5" BBS RK w/ Michelin Pilot Alpin's (winter) | New steering rack @ 1.2K & 17K miles| Software V.19.1 | B&B Exhaust (vrrrroooooommm!) <---Click.
Rudy is right yet again!
![Worthy](https://5series.net/forums/images/smilies/imported/worthy.gif)
My Ride: G30 M550i
Model Year: 2018
Originally Posted by joepoole' date='May 30 2005, 10:14 PM
If it re-occurs, I will attempt to change the channel, and see if it clears.
Thanks
Joe
Thanks
Joe
[snapback]134643[/snapback]
My Ride: F02 LCI Individual
Model Year: 2013
Originally Posted by realtyman' date='May 31 2005, 04:18 AM
Rudy is right yet again!? ![Worthy](https://5series.net/forums/images/smilies/imported/worthy.gif)
[snapback]134645[/snapback]
Originally Posted by Rudy' date='May 30 2005, 11:17 PM
[quote name='joepoole' date='May 30 2005, 10:14 PM']If it re-occurs, I will attempt to change the channel, and see if it clears.
Thanks
Joe
Thanks
Joe
[snapback]134655[/snapback]
[/quote]Yup, my password isn't one-D-ten-t for nothing.
Joe
bestofthebest
03-28-2016 02:47 PM
bestofthebest
01-05-2016 07:47 PM
Bank$hot530
07-12-2015 04:36 PM
rackhacker9275
26
04-16-2015 08:13 AM
