Engine Vibration - Is it serious?!
#22
Cann't be mounts, I changed them already.
http://i1086.photobucket.com/albums/...e/DSC_0339.jpg here is the link
![](http://s1086.photobucket.com/user/Nika_Bakhtadze/media/DSC_0339.jpg.html)
#23
My Ride: E60 M54
Model Year: 525i 2004
Back to your flywheel, did that fix the vibration? What were the symptoms of your broken flywheel?
#24
One day after pushing the engine got loud at 2500RPM, and later that night I heard very bad sounds when car stopped, it was like a tractor... then car turned off on me(broken part hit the sensor there)
It didn't fix the vibration.
#25
My Ride: E60 M54
I am hearing from people that increasing the idle RPM to 750 helps the vibration, I am not convinced on this. Does not anyone know to change the idle RPM without going to the $tealer.
#26
My Ride: E60 M54
Any further updates guys? Any of you having the issue already, tried the RPM increase with the $tealer? I am looking into INPA for engine adaptation reset, but not 100% sure yet.
#27
My Ride: E60 M54
Some update from me on this issue so far, two people have confirmed that increasing engine idle to 750 has helped and in my persuasion to attempt and code the engine idle RPM myself, I am stumbled upon something strange from INPA. Under Engine->Status->Analog->MWB1, I see "Engine speed" and "LLR normal RPM", they differ by 20rpm i.e. Engine speed sits on 640rpm and LLR normal RPM is 660. From what I understand by changing gears and driving around, "Engine Speed" is what is running and "LLR normal RPM" is what the car is codded to behave in that condition. When the difference between these two go really high say 40-50RPM the car starts to get the $hits and shakes/vibrates etc
Image attached, can any of the owners who have this problem got INPA functional and can verify this symptom please? And, does anyone know if the above theory is correct and how to fix the difference? Is this a software or a mechanical fault.
P.S. Since "LLR normal RPM" sits at 660 and that is what the hidden menu display as well, I believe the BMW recommended RPM for M54 engine should be 660 at normal idle at normal temperature i.e. 93F (in-line with the thermostat). And then this number changes according to the condition of the car and the ECU keep monitoring the engine and the programmed number accordingly.
#28
My Ride: E60 M54
Does any one know what the LLR Normal RPM means?
Also, vibration or no vibration, the Engine speed sits on 640RPM and the "LLR Normal RPM" was sits on 660 RPM. So is this problem really related to software and engine RPM at all or something else?
Any help is welcome.
#30
My Ride: E60 M54
Has anyone came across a service item from the $tealer that says "1199 recalibrated air/fuel 6884"
Apparently, recalibration of fuel injector/Air is the solution to this engine vibration on M54 engines.
Any experts here know what "1199 recalibrated air/fuel 6884" means from the $tealer? And if yes, can this calibration be done via INPA, NCSExpert, DIS, Tools32 or anything else....???
