Engine noise need help please!!!
Old 05-21-2013 | 06:40 PM
hendrich's Avatar
My Ride: E60 525i
Default Engine noise need help please!!!
Need help with this noise the car is a 545. Someone said the noise comes from a bad AC clutch but not sure about it. Thanks in advance guys.
Old 05-22-2013 | 05:13 AM
Margal's Avatar
My Ride: 2005 E60 545i Manual, Sport, L7
Model Year: 2005
Hope not the internal parts. Maybe the tensioner or idler pulley or water pump. Check them first.
Old 05-22-2013 | 06:52 AM
best1's Avatar
My Ride: 2008 550i M-Sport
Does the noise change when the A/C is on or off?
Old 05-22-2013 | 09:42 AM
hendrich's Avatar
My Ride: E60 525i
@best1 I don't know, this a car I'm buying and have this issue, I will check if the noise change w AC on.
In the case it does change, what could it be!
Old 05-22-2013 | 12:18 PM
EddieboyS's Avatar
My Ride: 2006 550i, 6 speed manual
I had to replace the overhead camshaft in my 85 MB 190e at about 160k miles. The noise it was making at the time sounded awfully similar. I would be wary of purchasing this vehicle.
Old 05-23-2013 | 12:14 AM
west's Avatar
ah yes. the n62 click sound.
Old 05-23-2013 | 07:04 PM
H F's Avatar
H F
My Ride: 2005 545
That sounds like a freakin rod knocking ,,
Old 05-24-2013 | 08:33 PM
turboawd's Avatar
My Ride: 2006 BMW 550i
a rod knock would sound deeper and maybe louder. this sounds like a collapsed hydraulic lifter or loose valve rocker. something on the upper end valvetrain.
Old 05-25-2013 | 11:36 AM
Germese's Avatar
My Ride: 535i Stock---for now
It could also be something as simple as an exhaust leak or low oil....
YannickVT
05-07-2015 11:45 PM
Guitarjon
04-11-2015 04:24 AM
TexaZ3
04-08-2015 10:50 AM
blk550
03-14-2015 11:02 AM
apeshape
09-16-2003 03:45 PM
Quick Reply: Engine noise need help please!!!
