ENGINE MALFUNCTION, REDUCED POWER - Error message
#62
Originally Posted by good anti' post='568202' date='Apr 25 2008, 02:48 PM
thanks so much for all your suggestions and help Glock i appreciate it.
I assumed you had your engine running to clear the lights. I noticed yesterday (when I removed mine), if you just turn the key on without starting the engine the lights will stay there until you re-start the engine then takes a few seconds to clear. When I do get the lights (upon initial install or removal) the pedal is dead too, like yours.
I took mine off and I think I am liking it better without it anyways. Granted I am driving an M5 so I don't really know why I need it to "feel" any faster anyways. Well I think I would like the option to turn it on or off and I might try to wire a switch or just sell it...
Good luck...
#63
My Ride: 2004 BMW 525i Mtech front bumper, M172 rims, 2007 Audi Q7 4.2L
Originally Posted by Glock-357' post='568313' date='Apr 25 2008, 08:25 PM
Your welcome. I am kind of bummed we couldn't get to the bottom of it with yours (seems like just a waste of time since all this did not yield any results). Maybe you can find someone who has a known working one and give it a try or try yours on theirs.
Good luck...
Good luck...
i don't get it any other time.
i have read over your posts several times but i feel I'm missing the meaning of clearing the lights.
have you heard of any BMWs that no SB will work in?
could this be a software problem or upgrade that needs to be done to fix this problem?
in any case i am sending back the SB to the user i bought it from to see if it still works in his car on Monday.
#64
Originally Posted by good anti' post='568330' date='Apr 25 2008, 05:42 PM
the lights only come on when it is installed and the engine is running.
Alright, as far as clearing the lights (think you did this)...
On my car 3 out of 4 times (installing or removing). I got DSC malfunction, red cog of death, etc. and the pedal is dead...
I turn the car off, wait and then start again.
Lights did not seem to clear at first upon restarting the car, but a few second later they went away (maybe one warning remained until holding the check button).
I press the Check Controls button on the blinker arm and hold it, and it comes back "Check OK" and no more warning lights. Pedal now works...
Living without SB...
Anyways, I am liking it very much without it. Just a lot smoother and I really feel like I can take it easy or put it in sport mode and just have to push a little further on the pedal. This thing kind of trained me to push further on the pedal, now with it off when I want the same feeling I had with SB on. Also on long trips my leg actually gets soar as a result of the SB.
So far I am actually loving have the pedal travel back and to be able to cruise at ~1/4 travel instead of just 1/64 or coast throttle, coast throttle... I'll report back if I start to miss it, but I think I am done with the SB for now (it will sit in my trunk for when / if I am ever in the mood).
#65
My Ride: 2005 545, Titanium Gray II, 6 Spd, CWP, Sat, LPP Laser Defense, V1 (hard-wired), iPod, 38% ceramic tint, CDV delete, H&R Street Performance Coil Overs, Forced Air Induction, DriveData Pro Camera System (4 cams), M5 Front Bumper
Originally Posted by bradleyjs' post='556565' date='Apr 5 2008, 01:46 PM
Ok, thanks.
FYI: My Engine Malfunction.. warning never cleared itself (after 60+ miles) so I cleared it myself with a OBD-II Reset Tool and the car runs just fine. Also, I returned the SB for a refund... I'm still bummed that I wasn't able to use it--I'll get over it.
I'm having the same problem. Which reset tool do you have? I'm trying to find one that is appropriate (and ideally one that also resets the airbag light... I tripped that once during a mod and it cost me $100 to get it reset).
Awest91
09-17-2022 11:05 PM
