engine light comes on - engine shakes
Old 04-21-2014 | 08:59 PM
nazboy84's Avatar
My Ride: 2008 528i
Default engine light comes on - engine shakes
Hello all,
I am hoping maybe someone can help me if they have experienced the same issue.
I have a 2008 528i 85k miles and over the last two weeks my engine light comes on twice and the engine starts shaking roughly/vibrating. I pull over shut off and turn on the engine and the shaking goes away. The two times when it happened is when I pressed on the pedal hard to accelerate quickly. At the same time when I did accelerate quickly the car appeared as if it didn't have power and the engine felt like it frisked/skipped and that's when the engine light comes on and the engine starts shaking. I restart the car and the shaking goes away. I also feel something different even if I am just driving on a highway doing 65mph and if I need to accelerate if feels as if the car (only sometimes) doesn't have power or isn't sure what to do and kind of stalls for a sec but eventually does accelerate and goes. Could it be a bad spark plug?
Two things I did. I changed my oil about two weeks ago. Also I had to get regular gas at BP for 20 bucks as they didn't have Premium and I was running very low and needed that to get to the next gas station. I have always used and use Premium gas for this car. First I though the issue was maybe bad gas but since then I burned through two full tanks of Premium gas and the issue still persists.
If anyone has any thoughts please do let me know.
Thanks all
Old 04-21-2014 | 09:21 PM
e60rider's Avatar
My Ride: 2008 528xi (Silver)
Did the issue happen when the gas was put in (when regular octane gas was in tank)? Also not much we can say, if u don't get the code read out. Its free at auto zone, i would think it may be a bad coilpack as misfire would cause shake. But this isnt guessing game, you dont want to be throwing expensive parts/labour at the car and have positive result. With the codes it will give a better idea and give a general area to look for the cause of shaking
Old 04-21-2014 | 10:40 PM
turboawd's Avatar
My Ride: 2006 BMW 550i
a tired fuel pump?
maf sensor going wacko?
its hard to tell. start by pulling the codes like mentioned, to get a starting point.
Old 04-22-2014 | 06:53 AM
twh's Avatar
twh
My Ride: 2006 BMW 530xi 6MT
Engine: N52
+1 You need to read the codes. Sounds like it could be a lot of things. Wife's had a similar complaint that also went away after restarting the car -- the code was cylinder #4 misfire. I never did anything about it as it never returned.
Old 04-22-2014 | 07:15 AM
nazboy84's Avatar
My Ride: 2008 528i
Thank you, I will go ahead and get the codes this thursday and go from there. It might also be a good idea to clean the MAF sensor while im at it.
Old 04-22-2014 | 02:57 PM
RTSR1's Avatar
My Ride: 2007 525i
I had two coils go out at the gas station. Ran fine when I turned it off. Started running rough & missing on restart. I replace all the coils and all been well since. Had about 70,000 on it then.
Old 04-22-2014 | 04:37 PM
mtylerrose's Avatar
My Ride: 2008 535i
Originally Posted by nazboy84
Hello all,
Thanks all
I got this, too. The CEL was from a misfire, and the injectors were replaced under warranty.
Old 04-24-2014 | 12:57 PM
nazboy84's Avatar
My Ride: 2008 528i
Ok, went to autozone and they did not pull up any codes. Cleaned the MAF sensor and it feels much better. Will give it a few days to see if the issue still happens. Does anyone know once you clean the MAF sensor if it needs a few days to adjust?
Old 04-24-2014 | 06:50 PM
nazboy84's Avatar
My Ride: 2008 528i
whelp the issue didn't go away the car went into limp mode again. will have to take it to a real mechanic.
Old 04-28-2014 | 06:00 PM
nazboy84's Avatar
My Ride: 2008 528i
can anyone please confirm if these coils will actually fit and work on the 2008 528i bmw. I am getting mixed results from different websites and arent able to find the right part number on real oem bmw
Amazon.com: BMW Ignition Coil Bosch OEM 0221504470 (6 pcs) 0221504470 => 2011 1 Series M /2008-2010 E82 Coupe; E88 Convertible 128i / 2011 128i / 2008-2010 E82 Coupe; E88 Convertible 135i / 2006 E90 Sedan; From 4/06 325i / 2006 E90 Sedan; From 4/06 325xi / 2007-2011 E90 Sedan; E91 Touring; E92 Coupe; E93 Convertible 328i / 2009-2010 E90 Sedan; E91 Touring; E92 Coupe; E93 Convertible 328i xDrive / 2007-2008 E90 Sedan; E92 Coupe 328xi / 2006 E90 Sedan; From 4/06 330i 330xi / 2007-2010 E90 Sedan; E92 Coupe; E93 Convertible 335i / 2011 E90 Sedan; E91 Touring; E92 Coupe; E93 Convertible 335i / 2009-2010 E90 Sedan; E92 Coupe; E93 Convertible 335i xDrive / 2011 E90 Sedan; E91 Touring; E92 Coupe 335i xDrive / 2011 335is / 2007-2008 335xi / 2006 E60; From 4/06 525i 525xi / 2007 E60 525i 525xi / 2008-2011 528i / 2009-2010 528i xDrive / 2008 528xi / 2006 E60; From 4/06 530i 530xi / 2007 E60 530i 530xi / 2008-2010 E60 535i / 2009-2010 535i xDrive / 2008 E60 535xi / 2011 F10 Sedan 550i / 2010-2011 F07 GT 550i GT / 2010-2011 550i GT xDrive / 2011 550i xDrive / 2011 F02 740Li / 2011 F01 740i / 2009-2011 F02 750Li / 2010-2011 750Li xDrive / 2009-2011 F01 750i / 2010-2011 F01 750i xDrive / 2010 F02 760Li / 2011 760Li Alpina B7 xDrive / 2011 F01 Alpina B7: Automotive Amazon.com: BMW Ignition Coil Bosch OEM 0221504470 (6 pcs) 0221504470 => 2011 1 Series M /2008-2010 E82 Coupe; E88 Convertible 128i / 2011 128i / 2008-2010 E82 Coupe; E88 Convertible 135i / 2006 E90 Sedan; From 4/06 325i / 2006 E90 Sedan; From 4/06 325xi / 2007-2011 E90 Sedan; E91 Touring; E92 Coupe; E93 Convertible 328i / 2009-2010 E90 Sedan; E91 Touring; E92 Coupe; E93 Convertible 328i xDrive / 2007-2008 E90 Sedan; E92 Coupe 328xi / 2006 E90 Sedan; From 4/06 330i 330xi / 2007-2010 E90 Sedan; E92 Coupe; E93 Convertible 335i / 2011 E90 Sedan; E91 Touring; E92 Coupe; E93 Convertible 335i / 2009-2010 E90 Sedan; E92 Coupe; E93 Convertible 335i xDrive / 2011 E90 Sedan; E91 Touring; E92 Coupe 335i xDrive / 2011 335is / 2007-2008 335xi / 2006 E60; From 4/06 525i 525xi / 2007 E60 525i 525xi / 2008-2011 528i / 2009-2010 528i xDrive / 2008 528xi / 2006 E60; From 4/06 530i 530xi / 2007 E60 530i 530xi / 2008-2010 E60 535i / 2009-2010 535i xDrive / 2008 E60 535xi / 2011 F10 Sedan 550i / 2010-2011 F07 GT 550i GT / 2010-2011 550i GT xDrive / 2011 550i xDrive / 2011 F02 740Li / 2011 F01 740i / 2009-2011 F02 750Li / 2010-2011 750Li xDrive / 2009-2011 F01 750i / 2010-2011 F01 750i xDrive / 2010 F02 760Li / 2011 760Li Alpina B7 xDrive / 2011 F01 Alpina B7: Automotive
part 0221504470
thanks
Quick Reply: engine light comes on - engine shakes
