engine breather filter 530d 2006
Old Jul 13, 2009 | 05:07 AM
tattubato's Avatar
Hi,
I have been reading about the following on 530d e60
egr valve
swirl flaps
and decided to do some research on removing the casing on my 530d e60 2006 couple days ago there is no engine breather filter in there at all.
1. is there supposed to be one in there and read about old type plastic with foam and newer type all hard plastic that fits inside as a reaplcement.
2. for this year of my model 2006 is there no need for one at all but i cleaned out the casing anyway.
the car has only done 35,000 miles for a uk model what milage should be taken into consideration to do the above work
egr valve
switl flaps
thanks in advance
Old Jul 13, 2009 | 12:06 PM
Anzafin's Avatar
My Ride: Bmw 530d 2004
Originally Posted by tattubato' post='940658' date='Jul 13 2009, 04:07 PM
Hi,
egr valve
swirl flaps
egr valve
switl flaps
thanks in advance
Are you talking about the oil separator as an engine breather filter. Yes you should have it. Check this thread. Or do you mean the engine air intake filter. Well you should have that too.
What about EGR? Cleaning maybe? I cleaned mine at 53,000 miles and it sure was dirty.
Swirl flaps. Removing? No one can really say when should they be removed. They can last 10,000 miles or 200,000 miles or forever.
Kasmo
Jun 27, 2024 06:02 AM
Kasmo
May 7, 2019 03:30 AM
Hudson_CM
May 19, 2015 01:16 PM
Hudson_CM
May 8, 2015 10:33 AM
Mikethepanel
Apr 25, 2015 02:33 AM
