Engine behaving weird...
Old Oct 13, 2008 | 01:18 AM
aznunknownx's Avatar
My engine today seems to be acting lazy when I started the car this afternoon. The car was running fine in the morning but as it get colder this afternoon my engine's RPM seems to be running low when parked or at stops. Normally my car's engine stays at a steady 700 RPM after the engine warms up. However, this afternoon and tonight it was staying at 400-500 RPM which felt rather awkward. When I drive, my steering wheel vibrates slightly during stops and low speeds. When I take a slow turn at intersections it felt as if the engine would suddenly turn off or die. Could this be because of the temperature that's affecting the engine's behavior? I noticed that lately its getting a bit colder and colder each day since winter is coming and tonight was by far the coldest.
Old Oct 20, 2008 | 10:57 AM
SergeyM's Avatar
My Ride: 2007 BMW 550, Sport, Navi, PS, CWP, Sirius
Mine 2007 is acting similarly. RPM do not go below 500 though when stopped and I have vibration all the way up to 2000 RPM when moving. I suspect the latest software ( why the hell they did it?) that was installed during my last service visit. Anyone with any advice?
Old Oct 20, 2008 | 11:55 AM
NPe's Avatar
NPe
My Ride: M6 E63 Sapphire black Z3 Coupe R4Turbo Hellrot, semi race. (670bhp) Z3 Coupe V8Turbo design work ongoing, full race. Sold: 545i Titanium Silver
Probably software, as allways
If you had a couple of years old 545/550 I would say malfunctioning crankhouse pressure regulating valve(s)
Try unscrew your oil filler cap when engine is ideling. what happens is that the crankhouse pressure drop, and so does the idle rpm.
If the valves are not sealed pressure leaks out and rpm drop in the same manner.
Look at this page for part info #13
http://www.realoem.com/bmw/showparts.do?mo...hg=11&fg=15
For reference, people have had your symptoms, and the fix was replacing the valves.
Old Oct 20, 2008 | 06:11 PM
SergeyM's Avatar
Oh, no! Not a valve job again. My 545 engine never recovered after the valve job and died with only 15K miles on it. If 4.8 V8 goes too, it will be the last BMW I will ever own.
Old Oct 21, 2008 | 02:24 AM
NPe's Avatar
NPe
This valves comes for 18$ a pop, two is required.
Zimo
Apr 11, 2018 08:25 PM
DAVE H
Jul 6, 2015 12:27 PM
Adam530d
Jul 6, 2015 07:19 AM
530e60
Jun 12, 2004 08:08 AM
Beemer
Jul 5, 2003 09:57 PM
