electric water pump.
My Ride: 2007 525xi 140k miles
Model Year: 525xi
Engine: 3.0l
i'm new here was looking for some info on the electric water pump on my 07 525xi. got the overheating warning on the display, removed the pump and tried to bench test it. put 12 volts from a battery, negative to brown that came off the block and positive to the red. didn't run. should it have am i missing anything ?
thanks
thanks
My Ride: 05 530i M54
Model Year: 05 530i
Engine: 3.0 M54
You could of kept the pump in the car to test it. You can initiate an auto bleed and the pump will activate. Also in INPA it can be activated
Model Year: 525xi
Engine: 3.0l
i tried that, didn't work. thought i'd try bench testing it to eliminate anything on the car
Model Year: 05 530i
Engine: 3.0 M54
If it didn't work when it was in the car and you activated the bleed process then it's no good. You activate the bleed process to eliminate the pump while troubleshooting
545isprt
12-12-2012 02:11 PM
