I had the opportunity to spend a day at the track in a car control clinic yesterday, and found myself wondering about exactly when and to what the Sport button has an effect when enabled. The manual indicates it initiates "dynamic driving control", including:
" - The speed range of the engine is optimally utilized. - Gearshifts are faster. - The engine responds more spontaneously to accelerator pedal movements. - The steering responds more spontaneously to steering wheel movements. - In the automatic mode, the 6th gear is not engaged." Does anyone know if these enhancements apply similarly in each of the three overall modes, D, S and Manual? Or, does the Sport button mostly enhance D mode only, or D and S mode only? There are obviously several combinations here, and their effect would be dependent on what driving task was at hand to some degree. After trying several setups, for what we were doing at least (autocrossing), I just ended up in S mode with the Sport button pushed, but at the end of the day I couldn't tell the difference with Sport button on or off in S. Cal |
Never mind... I found this thread: http://forums.e60.net/index.php?showtopic=...rt+button\
I still am not totally clear about what incremental enhancement the Sport button accomplishes when in S or in Manual mode (i.e., is SSport enhanced over S, is MSport enhanced over Manual?). I couldn't really tell in the autocrosses yesterday in the S mode. I'll keep playing with it. Cal |
The difference is noticeable but I think it depends on how much you've driven the car. At first, I didn't notice much of a difference but now, I can always tell if I forgot to turn sport mode on. You just feel it not only in the throttle response but also the shifting speeds...
I assume you're right in that, I don't have a lot of miles in it yet for adequate comparisons... Do you also notice it in the steering response? By the way, you'll remember I was skeptical about Active Steering, but partly on your recommendation I went with it and I like it alot.
Cal |
Cal I can't say I notice a huge amount of change in the steering response. Maybe it has to do with the fact that I have AS? I've never driven a car with a sport button and no AS so I can't really say much more... |
As I understand AS operation, it varies the steering gear ratio depending upon speed and other inputs... so I thought maybe the Sport button is moving the variable ratio to a lower range, more direct response to steering wheel input, than would otherwise be the case when in just S or Manual mode. I'd be sure it's doing that in D mode. Another thing I'll try to observe when I have the chance some day to play with the button on and off.
Regards, Cal |
Well we know for sure Sport mode cannot change the when a "manual" shift occurs as that is controlled by driver unless you hit redline (upshift) or forget to downshift if slowing. Of course you can prevent even that upshift at redline (at least in pre-LCI) if you are holding the shift lever in gear. For instance, if you push and HOLD the shifter to force a downshift at the first permitted point per EGS software, and continue to hold the gear via the shifter then as you accelerate it will not upshift but bounce off the limiter. Have done that when I knew I would be immediately be deaccelerating for next turn on track/autocross run etc. So manual mode should just be better throttle response, and tightning of servotronic steering.
