E6x SMG Paddle Shift Coding Protool
My Ride: 2008 e61 xi m-package
So after having done all the steps to do a SAT SMG Paddle shift conversion, I went the route of doing a small circuit board for the SMG paddle connectivity for those interested. My question can the paddle-shift be switched to active mode using the coding function of ProTool?
If so anyone want to enlighten me as to how?
Cheers all.
Nicd01
Cheers all.
Nicd01
My Ride: 530d msport Lci 2007
My apologies for answering a question that you didn't ask, but this info may help,
when carrying out the full sat conversion The last step is to make sure the EGS module is set correctly for paddles. If you have paddles, you want the following setting:
PADDLES=wert_01, If you do not have paddles on the steering wheel, you need to set it to PADDLES=wert_00
I have previously done this with NCS_Expert, I have no experience of Protool, I'm interested have you done a shifter conversion also or only the steering wheel paddles?
bahamutzyro
05-13-2008 07:15 PM
