E61 530i N52 Oil Leak around but NOT OFHG!
Old 02-02-2019, 05:26 AM
OzE61's Avatar
My Ride: BMW E61 M-Sport Wagon
Update on where I am at with oil leaks etc to be useful for anyone experiencing issues.
Replaced the oil pan gasket as there was a pretty severe leak, however I am still getting a leak from the same area which looks to potentially be coming from the rear main seal / oil pan gasket i.e. between the engine and transmission.
My hypothesis at this stage is a failing PCV / CCV system causing excess crankcase pressure and pushing oil out through the path of least resistance.
Getting up to speed on the system to see if I can work out what would cause a blockage, as the common failure seems to be a failing diaphragm which would cause excessive vacuum rather than pressure build up.
DC5Series
07-10-2022 10:54 AM
rev run d
02-28-2016 07:35 PM
Z3r0115
06-29-2014 06:43 AM
DC5Series
E39 Discussion
04-24-2014 04:20 PM
Quick Reply: E61 530i N52 Oil Leak around but NOT OFHG!
