e60 wheel well contents
Old Feb 18, 2020 | 06:42 PM
scottalexander's Avatar
My Ride: 528i
Model Year: 2010 528i e60
Engine: N52k
Default e60 wheel well contents
I pulled out the wheel liner and examined the components in the wheel well.
Check out the Evap filter.
How many of you are replacing this filter?
Does it have a 4 year lifecycle? 10 year lifecycle?
Old Feb 19, 2020 | 10:16 AM
audiophool's Avatar
My Ride: 535xi
How about 'never'?
Old Feb 19, 2020 | 03:10 PM
seanjordan20's Avatar
Engine: 3.0 B58; 3.0 M54
It has a whenever I get rid of the car lifespan. Lol
Old Feb 19, 2020 | 03:33 PM
My Ride: 528i
Engine: N52k
When I received the 2a16 fault code recently (evap micro leak), I went searching for what was triggering the CEL.
I ran the ISTA evap test module with the car NOT running.
During the test, ISTA activated the dtml pump in the right rear of the car for about a minute or so doing a few test. However, ISTA didn't come back with any results that could be helpful.
During the test I could smell gas near the drivers side door. What I just figured out right now is, that gas smell has to be coming from the gas ventilation valve connected to the intake manifold. The valve is under all the electronics which is at the bottom of the intake manifold.
If gas smell was coming out of that ventilation valve, that might be telling us that is where the evap leak is located? Or maybe that is just part of the ISTA test and gas vapors are supposed to leak from that area?
Old Feb 19, 2020 | 03:55 PM
I had the same error a few years back changed the valve and line and problem was solved.
When it happened to me I would get the code and clear it a few weeks later it would come back. I eventually changed it no problems since
Old Feb 19, 2020 | 04:07 PM
My Ride: 528i
Engine: N52k
Let's talk about how you changed the gas ventilation valve.
It appears you have to do the entire job blind because you can't see under the intake manifold. You just have to feel around and:
- unclip the electrical harness
- unclip the two vacuum lines
- pull off the ventilation valve from a bracket that it slides into?
Is there any magic to removing the ventilation valve?
Old Feb 19, 2020 | 04:30 PM
Let me think. If I remember correctly I didn't change the pipe from the valve to under the manifold. The valve is held on by a rubber slip. Pull it towards you ( should be towards the drivers side) and unclip while hanging. Then reinstall. It should be self explanatory after you slide it off. The part running under the manifold I did not bother to change out since it was the valve that was bad
Old Feb 19, 2020 | 04:32 PM
Correction now looking at the picture I didn't change the long pipe. The short pipe you should be able to unclip with ease. Let me know if you have an issue. I could be wrong. I know one side I didn't change
bavarianx
Archived Sales
Apr 26, 2010 01:38 PM
PaoChe
Mar 27, 2010 11:55 AM
amoor_w2
The Competition
17
May 12, 2009 02:08 PM
fraz
DIY: Do It Yourself
Jan 17, 2009 05:56 AM
SV
Nov 6, 2003 06:24 AM
