E60 weak heat. No heat on passenger side.
My Ride: 2004 e60 530i
This is my second e60 and the heat is just horrible. Driver side gets kinda warm and passenger side is cool. I-drive in the winter settings. Any suggestions? Antifreeze full. No check engine light. Car warms up normal. I don't get it.
My Ride: 2008 535i
Water valve fail in the open position to allow water to flow to the heater core for safety reasons. I have seen a few clogged heater cores. You need to check the temperature of the hoses going and coming from the heater core with a IR temp gun.
Is your outside temperature gauge reading properly? That external sensor is used by the cpu to set the load and achieve proper inside temperature.
Thanks
Originally Posted by E60Japanese
It could also be your micro filter
If it's blocked it won't let the air through the heater radiator to get heat to your interior
