E60 Transmission oil flush?
Old 02-27-2011, 01:34 PM
  #141
AchtungE60's Avatar
My Ride: E60 530i
Originally Posted by irockthebear
Raj, How do you change the oil? I looked down at the transmission and it looked like a sealed unit, I could not find the drain plug, how did you drain the fluid? Is there a how to somewhere?
Thanks!
I assume you already found the DIY for this since you're giving advice to use Shell over Pentosin ATF+1. Correct? If not look under the car you will find a transmission pan which is plastic and there will be a drain hole int he middle with a big allen key hole in the middle.
Old 02-28-2011, 08:40 AM
  #142
gwf545's Avatar
My Ride: 2015 535D M Sport
Originally Posted by bha7176
Where did you find the ZF Lifeguardfluid6 for sale? I've been searching but can't find it anywhere?
Thanks.
This place sells the fluid and the pan as a kit at decent prices - around $230, but it looks like they are out of stock again. http://www.thectsc.com/
If you call they might be able to give you availability info.
Old 03-09-2011, 05:00 PM
  #143
irockthebear's Avatar
FYI guys, I got the parts at CTSC for $300 pan/oil/sleeve/bolts
then I went to EMW in Arcadia, CA and the dude charged me $250 for labor
Also I needed a rental so $50
Total cost = $600 for flush/pan replacement/sleeve/bolts
socale39
09-05-2023 08:30 AM
Kasmo
05-07-2019 03:30 AM
kongse
07-17-2015 03:29 PM
ZeZe
10-15-2003 12:58 PM
08-12-2003 11:41 AM
Quick Reply: E60 Transmission oil flush?
