E60 Transmission oil flush?
#131
My Ride: Mini Cooper
Originally Posted by uheenada' post='1045365' date='Nov 3 2009, 02:21 AM
It's a very stupid thing indeed just like they looking at me like weirdo when I bring my car for an oil change every 5k miles.
they think change at 7k km is mad but for us it not if we what to keep it for a long time
#132
My Ride: SOLD...Jet Black 2008 550i M Sport with SAT, black interior. RPI exhaust and air scoop, 35% huper optik tint all around, CF roundels, flat black kidneys, Springfield Armory XD-40 jet black in glove box, charcoal filter removed.
#133
Pinguhk, I have the same problem...all gears smooth except 3rd -> 4th. Did the ATF change cure the shift jerk problem?
#134
Great point! Too bad I'm at 80k miles though! Why is all this information amazingly different!
I must say I was sooooo suprised when the 3 dealerships in here in DC... Arlington, Sterling, and Fairfax all said the same thing. 100k miles!
Normally when I call these 3 I get 3 different answers. How difficult is it for a clear concise answer... I just want to do the right thing!!!
Hey..Brian
I'm from DC too. A newbie and just bought an E60 05 525i auto. I went to Autoscandia at Reston and the mechanics there couldn't notice any problem of my tranny. But I get that jolt while driving in D mode or DS mode from 3rd to 4th gear. It bothers me so much and I don't know what to do. She's got 79K and everything else runs strong. The mechanic told me about some software update may cure the problem. But I call this bull. I think she needs an ATF change. Do you agree? Have you gotten a quote for the change? man...it's expensive$$
#135
Hey..Brian
#136
The independent shop that changed my fluid got it from a BMW dealer. So even though dealers don't recommend changing it, they turned me away as well, they have the fluid
#137
My Ride: '07 530iSport PackageLuxury Packagemore to come
To sort of go along with the topic of this thread, when I had my oil changed recently the tech pointed out to me that my tranny pan was leaking a little and said this is not uncommon on these cars. He said I should keep an eye on it and if the leak worsens that I should have the pan replaced. Now, my car is CPO so I wonder if a leaking tranny pan would be covered and if so how would they address replacing it. I mean obviously if they have to replace the pan that means new fluid. I guess I'll see if the leak has worsened in about 5k miles when I get the oil changed again.
#138
My Ride: 2005 E60 523 executive
20"ASA / Bi-Xenon / Full M-tech / LED Angel Eyes / Matte Black Kidney's / LED Side Markers
Damn...my car is at 60K miles now...I don't suppose that the dealer flushed the tranny before delivery since they claim it is a lifetime oil
I have a 523...is it wise to change the oil on one of these as well, or is it just the V8 models?
#139
Thanks!
#140
My Ride: BMW 550i
Model Year: 2011
Below is what the Transmission manufacter says about maintenance. So if you drive harder and further, they advice you to change the fluid between 50k - 75k miles. I had a transmission pan leak at 53k miles, so I used that opportunity to change the filter/pan along with 5.5 litres of transmission fluid from BMW at $32.50 each. I plan to change again at 100k mile.
"5 and 6-speed as well as 4HP20 automatic transmissions:
ZF 5 and 6-speed as well as the ZF 4HP20 automatic transmissions are filled maintenance-free with specially developed partially
synthetic ATF oils. Maintenance-free fills are intended for normal operating conditions. Especially driving at very high operating
temperatures can result in accelerated aging or increased wear of ATF oils. In the event of operating conditions, such as:
- highway driving in top speed range,
- offensive, sporty driving style,
- frequent trailer operation,
being above average, oil purification (oil change) on automatic transmissions is recommended between 80,000 km and 120,000 km, or
8 years, depending on the load.
In each case, only released ATF oil may be used for oil changes. And oil changes must be performed in accordance with the relevant
specifications."
specifications."
