E60 Rough idle when stopping
Old Dec 17, 2012 | 01:19 PM
Original's Avatar
My Ride: 2010 535i M sport
Model Year: 535i / 2010
Default E60 Rough idle when stopping
Does anyone ever come out with a fix on the E60 for the rough idle when stopping at a light or completely park. It is very annoying. I already change spark plugs filters, techron fuel injector cleaner 3 bottles of 12oz disconnect battery few times overnight clean the throtle and the MAF sensors and just it seems that it’s getting worse I been reading and reading the forums but no one seems to find a solution, I should receive in two days the BMW USB OBD Frogman v41 Package DIS SSS NCSExpert INPA EDIABAS to diagnose the car (2008, 528i), I do not know how but I will try to figure it out or I will be asking for your help too.
Old Dec 17, 2012 | 03:16 PM
pcy's Avatar
pcy
good luck with the software installation and diagnosis.
I was thinking what is a 'Frogman' :-) You meant progman. IMHO, progman is complicated... it doesn't come with manual.
If it's only for diagnosis and battery registration and trans adaptation values reset and things like that, you only need to install INPA and EDIABAS. NCSexpert is for coding. It's not that difficult, but you can screw up the car if you are not careful.
Old Dec 17, 2012 | 04:34 PM
l1tech's Avatar
My Ride: 528
Model Year: 2009
There is a tsb that involves replacing the exhaust hanger mounted at the transmission mount. The hanger creates a rough idle feeling and also sometimes a noise in the car.
Old engine mounts can also create a rough idle feeling. In the last month I have done 2 sets of mounts on E60s for a rough idle feeling.
Old Dec 17, 2012 | 05:29 PM
Original's Avatar
Just received the sofware and though it was just going to be install and play but for someone that has not much experience with computers is looks like a nigthmare, wish never pay for it.
Old Dec 17, 2012 | 06:07 PM
jdmek998's Avatar
What is your car idling at? My idle was low(500) so I just had my local dealer raise the idle (750-800)and the car is smooth now. Maybe thats all you need.
Old Dec 17, 2012 | 06:54 PM
Original's Avatar
My car idle is about 700 and 600 but as soon I stop it does a vooow! for about 5 seconds and iddle drops a bit and car shakes too then it goes away for another 5 seconds and then it comes back again. I just request a return autorization for the sofware and will take the car to dealer instead.
Thaks everyone for their input
Old Dec 17, 2012 | 09:11 PM
Knockers's Avatar
I had the same thing happen to my 535i. I ended up having to replace 3 fuel injectors. Works great now!
Old Dec 17, 2012 | 11:46 PM
balbs's Avatar
My Ride: BMW
I had a similar issue which turned ou to be an ignition coil on its way out.
Old Dec 18, 2012 | 03:13 AM
Sonny...'s Avatar
My Ride: E60 530iA
Does all of you have automatic transmission? I probably feel something similar like you describing here in my 530iA (2006) - very often when I stop with "D", the car vibrate a bit in short waves. Idle moves like +/- 50rpm around 600. When I change gear to N or P - vibrating dissapear. So I got feeling it has something to do with transmission, I mean maybe mounting of transmission to body or something like that. Does anyone has similar experiencies?
PS: I bet increasing of idle to e.g. 750 will solve it. But I'm curious...
Old Dec 18, 2012 | 04:51 AM
Original's Avatar
My car is automatic, but I alwayas change it to manual it picks better
