E60 Rear Window Sun shade roller guide broke. Where can I buy these?
My Ride: Stock for now
Today I used the rear sunshade for the first time and it went up ok. When I went back to the car the little plastic roller guides that attach the shade to the lifting arms broke on one side. A little while later the other side broke off. Can these be replaced and if so where might I be able to get them from? I tried a search here and on goggle and did not find anything. If anyone knows the part number please let me know? Thanks, I hope its not one of those that I have to replace the entire unit due to little broken plastic clips.
Originally Posted by Rudy' post='852002' date='Apr 19 2009, 02:22 PM
Does this help?:
http://www.realoem.com/bmw/showparts.do?mo...hg=51&fg=40
Here are some pics of what I am talking about.
![](https://i107.photobucket.com/albums/m296/jd94534/Sunshade%20guide/Sunshadeguide001.jpg)
![](https://i107.photobucket.com/albums/m296/jd94534/Sunshade%20guide/Sunshadeguide004.jpg)
![](https://i107.photobucket.com/albums/m296/jd94534/Sunshade%20guide/Sunshadeguide005.jpg)
![](https://i107.photobucket.com/albums/m296/jd94534/Sunshade%20guide/Sunshadeguide007.jpg)
I am going to have to remove the entire shade so I can drill out the rivets. If you have any removal instructions that would be most helpful. I took off the three 8MM screws from inside the trunk but the unit will not move. It looks like its being held down but I could not see the bolts from the top side but can see the bolt ends from inside the trunk. Thanks for your help.
My Ride: G30 M550i
Model Year: 2018
If you look at page 3 of the .pdf in the following post:
http://forums.e60.net/index.php?s=&sho...st&p=264281 You'll see how to remove the roller blind.
I think you are correct that you won't be able to buy the small part you're looking for, just the entire assembly...
My Ride: E60 530i
Engine: M54
Originally Posted by JD94534' post='852223' date='Apr 19 2009, 10:09 PM
Rudy, I have tried that but it still feels like the 3 bolts are holding the assembly down in place. I am able to see the bolt ends from the trunk. Page 3 of the PDF does not show the 3 bolts that are threaded from the shelf side. I have already removed the 3 from the truck side that are 8mm and it still will not budge.
I am thinking to tackle this task too because I hear some rattle sometimes from that area while driving the car. If you were able to remove the blind, can you post the steps with pictures of the blind/parcel shell removal ?
Thanks,
My Ride: G30 M550i
Model Year: 2018
Originally Posted by Rudy' post='852264' date='Apr 19 2009, 07:46 PM
On page one, it mentions removing the trunk screws -- from the looks of it, there may be a total of four screws...did you get them all?
http://forums.e60.net/index.php?showtopic=...mp;#entry264281
Wondering if anyone has any pointers to removing the rear shade they may want to share? .
