E60 Pre-LCI Headlight Question
Old 05-02-2010, 12:33 AM
bip78's Avatar
If there it is a simple plug n go set up then happy days. If its a re-wire job id be a tad more worried.
Any pics/guide as to "how to" would be great!
Cheers
Ben
Old 05-03-2010, 12:49 PM
530dE60's Avatar
kerrh17 - just wondering....so you got the LCI halogen headlights and then put an aftermarket HID kit into it? I guess now it looks the same as OEM pre-LCI xenon? I have a pre-LCI halogen and wondering if this is the easiet way to get the OEM look. Is your way more simple than getting the OEM pre-LCI xenon or LCI xenon headlight?
Old 05-03-2010, 01:35 PM
BlaSTiWi's Avatar
Yeah I thought for the thing when I upgrade mine (but I did pre-LCI halogen to LCI Bi-Xenon) but unfortunately you have to cut off the plug and install new pin on each of at least 8 wire and feed each wire into a new plug per side using BMW retrofit kit. So more of plug-'n-pray ... as not exactly ready to go adapter.
Cheers
Ben
Old 05-05-2010, 06:36 AM
stiker's Avatar
My Ride: 535d M Sport / Carbon Black Metallic / Aluminium cube / black leather sports seats / Prof. SatNav / Bluetooth.
Originally Posted by jas_r_1
Any more info on this. I have halogens and would like to retrofit the LCI halogens and then add a HID kit. Please let me provide a DIY
+1 write-up please !
This would be a very popular DIY, there are quite a few of us with pre-LCI Halogen who would like the Xenon projector setup, especially with the LCI eyebrows.
Old 07-30-2010, 06:27 AM
greenjedi's Avatar
Hi there can anyone help I have 530d 2004 and just brought some lci headlight projector halogens to upgrade my pre lci reflector and got the retro kit from BMW but have hit a problem.
There are 2 blocks on the reverse of the pre lci and only one on the lci so not sure which wires go to where and would love some help please if at all possible as I tried BMW and got the Royal we do not offer this service of fitting or help response.
PLEASE NEED URGENT HELP!!!!!!!
Old 07-30-2010, 07:22 AM
BlaSTiWi's Avatar
You need to buy the retrofit cable kit (it has the new LCI plug w/ the connectors and also wiring for the tail lights) and along w/ that there's a printed manual but the PDF is available online here in the forum ... use the search ...
You need to combine those to 8+4 ping pre-LCI connectors into the new 12 pin LCI plug from the retrofit kit ... the manual will have info the function & which pin goes where.
Retrofit p/n 61-12-0-432-110
GL!
[... pics ...]
Old 08-01-2010, 06:59 AM
carlito-shisha's Avatar
I made this transformation.
this is the result
Attached Thumbnails E60 Pre-LCI Headlight Question-010820101504.jpg   E60 Pre-LCI Headlight Question-010820101504.jpg
Old 08-01-2010, 12:45 PM
jas_r_1's Avatar
My Ride: 2006 520d - 19" 172s- Remapped - LCI taillights V6 cables - LCI xenon headlights - Denison 500 with BTA1500 - led interior lights - OEM led number plate lights Planned mods: Folding mirrors - Modmynav kit - High gloss shadowline trim -
How about a DIY???
The BMW instructions don't seem that straight forward.
Old 08-01-2010, 01:14 PM
Everything works well
But i have un problem.
I have a message on the car saying that my rings do not work but all is good.
for the instalation yo need this picture and the retrofit cable
What is the solution for my problem
Attached Thumbnails E60 Pre-LCI Headlight Question-sans-titre.jpg   E60 Pre-LCI Headlight Question-index.jpg
Old 08-01-2010, 01:18 PM
this is the LCI 12 pin, you cut all cable of your pre LCI headlights and put in the new socket casing 12 pin
Quick Reply: E60 Pre-LCI Headlight Question
