E60 LHD on RHD headlights
Old Feb 9, 2012 | 02:34 AM
sd_dracula's Avatar
Do LHD halogen headlights work on RHD cars?
AFAIK they should have that little switch thing which swaps from left to right hand drive?
Old Feb 11, 2012 | 03:13 AM
markrl's Avatar
My Ride: 2008 E60 525i
The switch over levers that you refer to are sadly only found on the projector Xenon HID lights. If you have plain Jane Halogen (like me) then its back to the old fashioned method of sticking the masking headlamp converter pads on the lens.
Even with HID Xenon moving the levers does not gave a true right hand left hand conversion it merely blanks off part of the light pattern the equivalent of masking off the lens and is just for temporary use such as going on holiday or an excursion.
For a true conversion say moving from Ireland to Romania with a right hand drive car you would need to replace the headlamps to those that have the correct left hand drive lenses. This should with Halogen be a very straight forward swap.
Old Feb 11, 2012 | 07:43 AM
sd_dracula's Avatar
Yes that's correct I have checked that with BMW themselves and they have said the exact thing.
Kasmo
May 7, 2019 03:30 AM
tnycman
Jun 17, 2015 11:35 AM
BYS2
Mar 24, 2015 03:13 AM
ZeZe
Oct 15, 2003 12:58 PM
