E60 LCI cluster snapshot needed, please...
Old 05-16-2011, 03:51 AM
ZGERMAN's Avatar
My Ride: 2007 M5
Hi guys,
Currently having some issues with an Asian vendor, which does not seem to know the difference between an E60 (LCI and pre-LCI), and the E90 cluster, so it seems. As a result, their gauge faces (=overlays) for the E60 don't match my non-LCI cluster.
Can someone with an E60 LCI please post a picture of your instrument cluster? I'm especially interested in the RPM gauge...
TIA!
Armin
Old 05-16-2011, 03:59 AM
NavarroOne's Avatar
My Ride: E61 535d carbon black m-kit panoramaroof with beige nasca interior and wood trim. 172m rims. DimSport Race, SB, SAT
Check this thread. Mine is a diesel so redline is a bit lower than a gas powered car.
Old 05-16-2011, 04:06 AM
NavarroOne's Avatar
PS you can also always go on edmunds.com http://www.edmunds.com/bmw/ and select the car you want under the "research models". If you choose 5 series sedan (not just 5 series) then you can choose any year and see specifications and pictures from interior and exterior. Excellent site to research the changes that occurs between the years.
I also like this reference for differences between pre and LCI https://5series.net/information/2008...ed_Changes.pdf though not sure whether it goes in detail with the changes to the instrument cluster!
Old 05-16-2011, 10:07 AM
ZGERMAN's Avatar
My Ride: 2007 M5
I also like this reference for differences between pre and LCI http://www.5series.n...led_Changes.pdf though not sure whether it goes in detail with the changes to the instrument cluster!
Excellent!
Thanks much, NavarroOne. I'll check out those links some more in detail when I get home...
Cheers,
Armin
Old 05-16-2011, 05:54 PM
rbcook's Avatar
My Ride: 2008 Jet Black 528i Navigation, heated seats, premium
Here are pix from my '08 528i. The redline hash marks start at 6,750, and the actual redline is at 7K. Remember, the LCI tachometer does NOT have the variable segments that change with engine temp.
Old 05-16-2011, 11:04 PM
NavarroOne's Avatar
hm just noticed I forgot to paste in the link! https://5series.net/forums/topic/111...1#entry1325557
In any event you've already gotten an excellent answer on this thread but if instruments are your current passion, you may enjoy the above thread.
Old 05-17-2011, 10:54 AM
anaqvi's Avatar
My Ride: 530xi 2006 with nav and premium package
I looking to relocate to Houston, TX. I have Canadian version 530xi 2006, and looking to see if I can convert (and/or) add MPH gauge on the speedometer faceplate? Rest I can change w/ iDrive without any problem.
Any suggestions?
Kasmo
05-07-2019 03:30 AM
BMW565
11-06-2017 06:03 PM
lc holmfirth
03-22-2015 10:28 AM
ZeZe
10-15-2003 12:58 PM
08-12-2003 11:41 AM
Quick Reply: E60 LCI cluster snapshot needed, please...
