E60 key fob - convert soldered battery to 2032?
Hi,
I see lots of threads troubleshooting this issue and plenty of videos, but my question is:
I have a non-CA E60 key fob with the permanent (soldered) battery which no longers takes a charge. Can I simply transfer the circuit board to a new shell and unsolder the battery so I can use a replaceable 2032 battery?
If there is an existing thread on this, feel free to direct me to it.
Thanks!
Thanks!
Looks like you need a VL2020 rechargeable battery, they are available on Amazon, and here's a DIY video -
Thanks for taking the time to replay - you'll see that I'm looking at converting it to a fob with a *replaceable* 2032 battery rather than the rechargeable VL2020. Just wondering whether anyone has any experience with this.
Looks like you need a VL2020 rechargeable battery, they are available on Amazon, and here's a DIY video - https://youtu.be/vBpvDWIMr7g
mspswede (09-24-2020)
My Ride: 05 530i M54
Model Year: 05 530i
Engine: 3.0 M54
Originally Posted by donpb
VL2020 are on eBay too. Just put the rechargeable one back in and be done with it. The car is supposed to recharge it but that can only happen so many times before it stops charging and then the battery needs to be replaced. CR2032 may not be rechargeable and so while it may work, it probably would not work as long.
My Ride: 528i
Model Year: 2010 528i e60
Engine: N52k
What is the mean time between failure on the VL2020 soldered battery?
For example, is it designed to receive "X" number of charging cycles?
If so, what is X?
If so, what is X?
My Ride: 528i
Engine: N52k
Does that mean the CAS module figures out the VL2020 battery is at 90% charge and then kicks in to charge it to 100% (which counts as one of the 1,000 charge cycles)?
If so, now we need to figure out how long (or how many days) the VL2020 can hold a charge before it drops to 90% charged?
