e60 headlight Led
My Ride: 05 545i
I'm new to the forum and BMW world...my problem I just notice is when my headlight on does the corner led suppose to be on too if it do i need to change the bulbs or is it a fuse problem because it not lighting up...thx David
Krip, first of all, welcome to the forums. Secondly, I had to read your sentence about 5 times before I could decipher it. Third, yes, you should have the LED's lit when the headlights are on or even when the parking lights are on.
My Ride: 04 525i, 04 Dinan M3
From what I gather from reading the first post you are wondering why the eyebrow does not light up? Has it ever been on? Its possible the eyebrows may not be enabled, which the dealer can do. If they were previous working then it may be a bad connection or LED? Not sure if there is a fuse tied to that
As you've already read they should be illuminated when your parking or "normal" headlights are on. It looks like your headlight assembly is out of the car .. is it possible that the connector for the LEDs was disconnected? It's pretty unlikely they "burned out" from use.
My Ride: BMW
Did they used to work? Have you taken the car in for service that needed programing? From what I've read, a certain software update inadvertently disabled the "eye brows". Another software update fixes it.
My Ride: 05 545i
I got the pix from someone to show what I'm talking about but both side doesn't work and i just realize it has happen hen i saw other e60 was working...there no error, maybe it just need to be enable from the dealer...thx everyone for the help
My Ride: 530iA 04
My Ride: 2006 520d - 19" 172s- Remapped - LCI taillights V6 cables - LCI xenon headlights - Denison 500 with BTA1500 - led interior lights - OEM led number plate lights
Planned mods:
Folding mirrors - Modmynav kit - High gloss shadowline trim -
I think there are other members who have has this problem and I believe it's just a case of getting the dealer to enable them
socale39
09-05-2023 08:30 AM
Tsoup
15
12-20-2021 11:14 AM
