E60 Cooling Concern
Old May 23, 2025 | 03:53 AM
SB73's Avatar
My Ride: 2005 523i Titan silver manual completely standard
Model Year: 2005
Engine: N52
Default E60 Cooling Concern
E60 523i 2005 N52 Engine
The car overheated on a 20 mile run a couple of days ago, with amber then red warning signs displayed. Water was low so topped it up.
The cooling fan is now kicking-in when starting from cold, and the amber warning light has appeared on a short journey.
A diagnostic check has thrown up the following codes:
2EF5 Thermostat characteristic, activation (Intermittent)
2E82 Auxiliary water pump, switching off (Intermittent)
2DED Power management, quiescent current fault (Intermittent)
I am wondering if one of the 28 codes is a knock on effect from the other?
Any help or advice would be much appreciated.
Old May 27, 2025 | 05:36 PM
twh's Avatar
twh
My Ride: 2006 BMW 530xi 6MT
Engine: N52
Classic symptoms of a dying water pump.
You need a new pump and you can be stranded at any time without a lot of warning.
I would not drive the car until you fix it.
Old May 27, 2025 | 11:26 PM
donpb's Avatar
My Ride: '06 530i N52
+ thermostat
Old May 28, 2025 | 05:36 AM
SB73's Avatar
Model Year: 2005
Engine: N52
Thank you for the reply, any particular brand of Pump recommended or any brands to avoid?
Old May 28, 2025 | 11:13 AM
twh's Avatar
twh
Engine: N52
Many threads on this here and at bimmerfest.com
If you are doing this this is what you need for the fix and a couple preventative measures...
  • one gallon of full strength BMW coolant
  • one gallon of distilled water
  • one Pierburg water pump
  • one U-hose that attaches the pump to the thermostat -- this is a preventative measure since that hose is really hard to get to (this isn't absolutely necessary, but I have always done it)
  • one Mahle-Behr thermostat (this may not be necessary, but I have always done it)
  • one aluminum hose flange for the hose from the thermostat up to the engine block up near the oil filter housing -- looks like this -- Rein makes this one (this will break at some point for sure)
ES#3988529 - CHC0609 - Aluminum Coolant Hose Flange  - Upgraded metal flange for water hoses - Rein - BMW
MTranter00
Apr 15, 2024 11:27 AM
ukr
Jul 26, 2016 10:04 AM
BobbyS
Sep 8, 2013 09:35 PM
tonyb635
Apr 18, 2013 07:09 AM
one4thethumb
Jan 27, 2013 04:34 PM
