E60 code P3238
Old Oct 13, 2019 | 06:50 AM
joge's Avatar
My Ride: 2010 535 IX
Model Year: 2010
Engine: 6 w turbo
Default E60 code P3238
2010 535IX w 175,000 miles. Just did a walnut cleaning of valves, and installed new valve cover and gasket. Replaced both the Manifold Air Pressure sensor and Boost Pressure Sensor. These were done because I had, running lean on both bank codes with rough idle and hesitation on acceleration. Car accelerates much better and idles smooth most the time. Now getting a P3238 code occasionally with the "reduced power" message on the display. Shut of and restart, and it runs good. Any thought on what the next step would be in trying to find the culprit ? Doing a Google search resulted in several different areas that could be an issue. Thanks for your input :O)
Old Oct 13, 2019 | 06:59 AM
seanjordan20's Avatar
Engine: 3.0 B58; 3.0 M54
Were you getting the code before the work. Have you hooked up INPA to the car?
Old Oct 13, 2019 | 07:05 AM
joge's Avatar
Model Year: 2010
Engine: 6 w turbo
Thank you for asking. I just have a cheap OBII scanner. The P3238 code had not shown up before doing the work.
Old Oct 13, 2019 | 09:27 AM
I would back trace your work to make sure everything was plugged in correctly and tightened up. Also you need to get INPA to effectively troubleshoot BMWs
Old Oct 14, 2019 | 04:33 PM
joge's Avatar
Model Year: 2010
Engine: 6 w turbo
What INPA do people have the best results with ? I prefer not to spend a lot on it as I am planning on selling the car once it is running good.
Old Oct 14, 2019 | 04:54 PM
It's a software that can be found free if you look for it. The only thing you would have to pay for is the cable usually around $20.
How long have you've owned your car. INPA is a great tool to have when DIYing BMWs
Old Oct 14, 2019 | 04:59 PM
kd7iwp's Avatar
My Ride: 2009 535xi Touring 6MT, 2019 i3s
Engine: N54
INPA is free. An easy place to get it is from BinmerGeeks.net.
Old Oct 14, 2019 | 06:05 PM
joge's Avatar
Model Year: 2010
Engine: 6 w turbo
I have had it since it had 35,000 miles. The local experts at the dealer don't seem to be able to trouble shoot unless it sets a code that is 100% definitive. It runs much better with the clean valves, but still setting a lean bank 1 code. I am running injector cleaner presently to see if that makes any difference.......
Through research, I am suspecting a low pressure fuel pump, pressure switch, or injector issue.
Old Oct 14, 2019 | 08:06 PM
I don't think it's either. Have you back traced your steps yet. There's something you missed or a vacuum hose cracked while working.
Old Oct 17, 2019 | 06:41 PM
joge's Avatar
Model Year: 2010
Engine: 6 w turbo
Does anyone have a link to a INPA cable for 2010 E60 535IX that they have purchased and worked correctly?
