e60 auto trans problem
Old Feb 27, 2015 | 05:07 AM
seanjordan20's Avatar
Engine: 3.0 B58; 3.0 M54
Make sure you take the fill drain plug out before you drain the fluid. You dont want to drain it the figure out you cant get the plug out.
Old Mar 3, 2015 | 11:12 AM
416's Avatar
416
My Ride: e60
Transmission oil was full and clear
Old Mar 3, 2015 | 11:57 AM
If you checked the fluid while the car was leveled then it is time for a valve body fix. Search for KyleB's DIY and read it. Might find something interesting
Old Mar 9, 2015 | 08:16 AM
416's Avatar
416
My Ride: e60
Is the valve body the megatronics
Old Mar 9, 2015 | 11:59 AM
KyleB's Avatar
My Ride: 530i
Engine: M54
'Mechatronic'
yes, they are one in the same.
Old Mar 9, 2015 | 04:59 PM
Yes they are but it is actually two parts that make it up. The VB and TCU. The TCU separates from the VB. The two parts have to stay together (meaning you cant replace one without replacing the other). You can separate them to work on the VB.
Old Mar 11, 2015 | 09:29 AM
pcy's Avatar
pcy
...So I did more research and found a guy who can rebuild my valve body for $600 (new solenoids and better gaskets with a lifetime warranty) so I took this option. ...
Sean, can you give me the contact details for the guy you've used for valve body rebuild?
Thanks.
Old Mar 11, 2015 | 01:35 PM
World Wide SP
Matthew Cilwa
(513)886-1215
He goes through a company call VBX that is in Virginia and owned by Sonnax. It took them 2 days to rebuild it and have it back in the mail. They say it takes 3-5 days though. You can talk with Matt and have him do next day air both ways if you cant wait long. The price will reflect the extra charge for rush shipping. I also went to CTSC to purchase the Mechatronic Seal Adapter and oil change kit. Pelican parts had the other parts I needed for the install which are the sealing sleeves. The sealing sleeves are hard to find so if you can get them from the local dealer go ahead and grab them. They run between $17-$23 a piece.
If you call Matt let him know his buddy Charles sent you. He will take care of you.
Old Mar 11, 2015 | 05:04 PM
pcy's Avatar
pcy
Thanks, I'll call him tomorrow.
Transmission on my car is working perfectly with no problems other than the sleeve just started leaking. When I replace the sleeve, I figured I'd overhaul the mechatronics and replace all the seals. I already bought the bridge seal, 4 tubular sealing sleeves, I was just contemplating buying the solenoids. I will ask Mat if he will test the Clutch Control Pressure regulator valves as part of the service.
Old Mar 11, 2015 | 05:11 PM
Matt is an authorized person to do business with the company. You have to have a license I guess. But what the company does is take the VB apart and replace all gaskets solenoids (if they are bad) and check/correct misalignments. Once they are done the hook it up to a machine like it in a trans and check for pressure loss an other things. They also give a lifetime warranty on their work. If you click the links in the post the website will tell you everything you need to Know
Nihilation
31
Dec 27, 2021 06:40 AM
Kasmo
May 7, 2019 03:30 AM
bbbamboo
Sep 17, 2017 04:33 PM
rizwan1377
Apr 5, 2015 05:22 PM
ZeZe
Oct 15, 2003 12:58 PM
