E60 Alloy Wheel Cracked
My Ride: Now Driving a Freakin' Prius!
Was...
2004 545i | SMG | White/Black | Sport | NAV | Logic 7 | PDC | Fold-down Seats | Adaptive Headlights | Cold Weather Pkg | Clear-again Bra | Mud Flaps | Bluetooth | Coat Hangar | Aux Input | All Weather Mats | 18"X8.5" BBS RK w/ Michelin Pilot Alpin's (winter) | New steering rack @ 1.2K & 17K miles| Software V.19.1 | B&B Exhaust (vrrrroooooommm!) <---Click.
Originally Posted by evperry' date='Feb 13 2005, 05:48 PM
I has the EXACT same problem last week.? my rear rigth wheel cracked the same way.? i tell u this, i did hit a hell of a pothole.
[snapback]89800[/snapback]
My Ride: Met Blue2004 530iSE Sport Body Kit, 18" alloys with RFT (and no Jack or spare!!!)
UPDATE:
BMW have replaced the split alloy as a gesture of good will. I replaced the tyre. I tried to make the point that the other 3 wheels may be at risk but they were having none of that. I've accepted the gesture and will start saving for a set of M style alloys. (New M Body Styling Kit being fitted today!)
Originally Posted by smarty marty' date='Mar 2 2005, 04:29 PM
UPDATE:
BMW have replaced the split alloy as a gesture of good will.? I replaced the tyre.? I tried to make the point that the other 3 wheels may be at risk but they were having none of that.? I've accepted the gesture and will start saving for a set of M style alloys. (New M Body Styling Kit being fitted today!)
[snapback]96232[/snapback]
Originally Posted by wolverine' date='Mar 2 2005, 02:45 PM
I suspect BBS has a problem with a batch of these wheels.
[snapback]96248[/snapback]
Originally Posted by EBMCS03' date='Mar 2 2005, 08:25 PM
[quote name='wolverine' date='Mar 2 2005, 02:45 PM']I suspect BBS has a problem with a batch of these wheels.
[snapback]96365[/snapback]
[/quote]When there is a mfg problem with anything, it is almost always limited to a batch or set of batches. Sometimes it is a faulty process that is used for a while and then modified. Sometimes it is bad raw material that is used in a series of batches. Or it could be a bad fixture or casting mold, or any number of things. The chance that it affects ALL 124 wheels is slim, unless they were all produced at about the same time. It is likely that BBS knows about the problem with your wheel and has corrected it for subsequent batches. I would contact them and/or BMW.
My Ride: 2011 535i... Alpine White, Black Dakota, Anthracite, Premiium 1+2, Sports Package, Comfort Access
Driving home from work today I hit a pothole, at a speed of 60 mph or so. Didnt seem like anything worse than some other potholes Ive hit before. A few secs later I heard a noise that sounded kind of like I had a flat tire. I pulled over after about 1/4 mile to the shoulder and looked at the tire. It looked fine. So I kicked it and heard a rattling kind of noise. Then I remembered this thread, and decided to grab the flashlight to take a closer look. I found my rim cracked just like the ones posted all the way around the rim. No damage to the tire or scratches on the rim.
Originally Posted by bklyn545' date='Apr 4 2005, 05:41 PM
Driving home from work today I hit a pothole, at a speed of 60 mph or so. Didnt seem like anything worse than some other potholes Ive hit before. A few secs later I? heard a noise that sounded kind of like I had a flat tire. I pulled over after about 1/4 mile to the shoulder and looked at the tire. It looked fine. So I kicked it and heard a rattling kind of noise. Then I remembered this thread, and decided to grab the flashlight to take a closer look. I found my rim cracked just like the ones posted all the way around the rim. No damage to the tire or scratches on the rim.
[snapback]111167[/snapback]
Uh O... are you included in that "batch of bad rims" or ... have we figured out when the build dates were for all thses cracked 124 rims?
