e60 aircond and fan problem help!!
I would double check and make sure you check the pressure charge for your AC. That also can make your fan run that high. When you check the pressure check it with two different pressure gauges to make sure you are getting the correct reading. How many miles do you have on it? I am not saying that its not the pump, its just unlikely at this point.
ok will check tomorow and see what psi my car have.is this recommendation is for my fan problem or air cond problem?...if it is for my air cond problem,i change my compressor only 1 week back but the air cond problem was there for almost a year
im trying to activate the temperature menu but when it come to the last step which press 7 times,when it comes to tht menu after 2-3seconds it goes back to my clock and outside temperature and its not showing the engine temperature?can someone guide me im using 525/08 lci model.tq
[/quote]
I would to go an Indy shop to make sure I the right pressure is set. If you rather go to the dealer go ahead. Check this video out to help you with knowing your temp.
[/quote]
I would to go an Indy shop to make sure I the right pressure is set. If you rather go to the dealer go ahead. Check this video out to help you with knowing your temp.My link
DavaiLave
Aug 2, 2022 02:16 AM
