E60 530i No dash no ignition no crank
Old 12-01-2019 | 11:12 AM
seanjordan20's Avatar
My Ride: 05 530i M54
Model Year: 05 530i
Engine: 3.0 M54
Try to put the key in the ignition for about 5 mins with it in the on position. Turn it off then try to start it.
Old 12-01-2019 | 11:14 AM
Model Year: 05 530i
Engine: 3.0 M54
Originally Posted by Nirmal Taukoor
Oh, so if the transponder can't read the key, the dash lights wouldn't?
I thought it would but won't start.
That's the thing the dash should light up you just shouldn't be able to start the car. This is why I say a module. Are you sure your battery is good? How old is it?
Old 12-01-2019 | 08:16 PM
Nirmal Taukoor's Avatar
My Ride: 2004 E60 530i (M54) with 6HP19 auto transmission
Engine: M54
​​​​​​Good day,
I'd switch the battery with my E46, and it is still the same. It means the battery is definitely fine.
Old 03-08-2020 | 06:41 AM
Engine: M54
Hi guys,
Finally FIXED, apparently, the CAS module was dead. Had to replace a set CAS/DME/Keys/ignition barrel and lock set, door and trunk.
Painful financially but satisfactory in the end, have it running.
Thanks so much for all your support, which lead me away from taking wrong steps.
Kindest regards😃
Old 03-08-2020 | 09:40 AM
Model Year: 05 530i
Engine: 3.0 M54
Glad to hear you got it fixed. Why did you have to replace everything instead of just the CAS with a recode and pair
Old 03-10-2020 | 02:57 AM
Engine: M54
😭 didn't know that, the technician advise that CAS cannot be code l, he probably wanted to sell me the set! Lol
how do you recode the CAS? Using which software, I recent got my INPA /ISTA D and P... With NCSexpert and Progman.. not yet installed and tested.
Old 03-10-2020 | 04:22 AM
Model Year: 05 530i
Engine: 3.0 M54
You can recode the CAS using NCS, winkpf and toolset. Once it's coded you need someone who can add the keys. It's about a 90 min job to code a new CAS and software update but it definitely can be done.
inkr3dibl3
06-03-2022 09:14 AM
chandy
05-18-2015 06:35 AM
E60I
08-03-2013 01:13 PM
pestilence
04-26-2012 08:28 AM
mk23169
04-22-2012 12:31 PM
Quick Reply: E60 530i No dash no ignition no crank
