E60 530i help needed metallic noise from driveshaft
Hi guys , new on here and looking for some help.
My e60 530i has developed the tinging noise from the drive shaft when putting any sort of heavy load ,eg setting off forward or reverse. Had drive shaft off and greased center splines and checked cv joint. Fault fixed for 50 miles then came back. Mutherf@&Łer !!!!! Any help would be appreciated. Thanks !!...
My Ride: 2005 BMW 545i sport package
I had this issue before and the car needed a new drive line. Try to find Indy shop to fix it for cheaper cost. BMW dealer quoted me for $2500+ for parts and labor.
Is the problem intermittent? How do you know it's the driveshaft? I once had this issue and it was a butterfly valve in the exhaust causing the issue. I replaced the guibo disc and everything for nothing. for a $0.97 fix LOL. I was young and inexperienced.
Car now fixed, replaced faulty centre bearing. Now drives perfec !
Thanks guys
My Ride: E60 525 M Sport
