E60 528i 2008 won't crank - INPA CAS voltages diagnostics
My Ride: E60 528i
Engine: N52KP
Hello everyone!
I would like to request some help trying to repair my BMW. It recently stopped starting (no crank, though I hear the fuel pump) et I decided to change the starter thinking it was the issue (it was very old and I should have changed it anyway). It turns out that it wasn't the problem because there is still no crank.
Using INPA, I get a few errors including a very unhelpful one (A0B4). I have confirmed that the brake pedal is correctly detected as down in the CAS diagnostics. I recorded a video of me trying to start the car with the voltages values from the CAS diagnostic page.
I am starting to suspect a flaky cable between the relay and the starter.
Battery is very healthy and fully charged (and paired when installed).
Any help would be welcome
My Ride: E60 528i
Engine: N52KP
To anyone who encounters this in the future: it was a bad ground between the engine block and the chassis. The braided cable was extremely oxidized.
