e60 2005 making beeping noise
Firstly hello all
im new to this site someone i know has just told me about it
can anyone please help or advise me.
my car is a 525d 05 reg e60
when my car is locked or unlocked there is a beeping every 2mins or so coming from inside the car its not really loud but if you are stood near the car you can hear it
as soon as you start the car it doesnt beep again
i have checked the alarm-- which is fine
i have checked the fuses again all ok
i have looked on the i-drive and this is showing no faults
i now have no idea
i really hope you can help
Thanks i look forward to your replies
i now have no idea
Sounds to me like some sort of silly aftermarket add-on, or an option that may only be regionally available. I have seen several times alarm systems that decide that making constant, repeating noises to 'confirm' that the alarm is, in fact armed, but mostly asian imports. If it were my car, I would make a top priority of removing that - unless someone else replies saying it is factory.
Have you tried sitting in your car and hitting the lock button on your remote to try and hunt the sound down? If you hit the lock button twice you will arm the alarm but disable the motion sensor so you can crawl around your interior until you locate the culprit.
My Ride: 2005 545i E60 Orient Blau Metallic
Premium, NAV, Winter Package, Heads Up Display, Logic 7 Audio, AngeliBright Upgrade [White], M5 Body Kit, M Embroidered Seats
iCharles brings up a good point. This is not a standard BMW feature. Perhaps you have aftermarket equipment installed. Have you checked to make sure your HOUR MEMO isn't enabled in your date/time settings? Would be nearly impossible for that to be the cause and it shouldn't do it when your car is locked but double check it in any case....
i am a very happy man ive found an aftermaket nokia carkit installed so ive disconnected
the dame thing and now i am the proud owner of a beeeeeeeep free e60 BMW
Thank you everyone for there advice.
Cheers Mark
Cheers Mark
My Ride: 2012 535i M package
Originally Posted by mark69' post='779377' date='Jan 28 2009, 01:28 PM
Firstly hello all
i now have no idea
i now have no idea
man if it is what I am thinking, thats the fuel pump I believed.. is the noise like i.e.. you car is in the garage and you open a door or turn the light with your remote?
then gets a sound and after a few minuts goes away ?
Stormcrow
12-01-2019 02:09 AM
Guitarjon
04-11-2015 04:24 AM
