Dynamic headlights
My Ride: Numero Uno in Richmond Va 04 530 6 speed, jet black, black dakota leather, xenons, red rear reflectors, 545 front grill, cold weather package, premium package, staggered 19 inch BBS rxII/michelins, H&R coilovers and intergrated, R1 concept drilled an
Engine: 530i
You have a K-Line error throughout the car. You have to solve that before you can fix your lights if there is an issue with them. You stated the parts work in your friend's car so to me there's no issue with the light system. You said ISTA pointed the ALC and you replaced it correct? Did it fix your issue? If not then you have to start troubleshooting beyond ISTA. This is where the dealership gets owners to spend unnecessary money because when ISTA is not correct they start guessing. Again your codes are obviously pointing to a K-Line fault to an experienced BMW mechanic. Find the issue and your lights and all the other K-Line fails will be fixed.
Engine: 3.0 B58; 3.0 M54
Correct your ISTA connection settings then post the error readout. As of now I don't see anything wrong with you LM so your lights should be good
Engine: 530i
In ISTA too right you see the wrench, click it. Go to connection settings and ensure it says EDIABAS. Now go to .ini file and ensure your EDIABAS settings are correct. More than likely it's your latency setting in the USB settings in device manager. Ensure it's set to 1.
Engine: 530i
In ISTA too right you see the wrench, click it. Go to connection settings and ensure it says EDIABAS. Now go to .ini file and ensure your EDIABAS settings are correct. More than likely it's you latency setting in the USB settings in device manager. Ensure it's set to 1.
Engine: 530i
Thanks for your help they are working factory reset worked
Good thing you got it fixed. This was the craziest thread ever. It had me all over the place Now I'm wondering if all the parts you replaced are still good.
Engine: 530i
I wonder the same maybe just the AHL was bad or rogue that I don't remember if I put that one in his car or the new used one, now i just have to adjust the sensitivity the lights are one in full sunlight, i do remember having the dealer fix this when i brought the car new and i guess the factory reset put them back to new. Ill mess with it in protools and ista after reinspection today thanks again. Now on to the other errors
bmwmonkey
May 19, 2020 03:04 AM
