Dynamic Drive malfunction
My Ride: 530i Loaded to max
Hello everyone,
I have a 2004 530i that's been giving me troubles on and off for over a year now. I'm getting error messages like the infamous Dynamic Driving Malfunction or Passenger Restraint error that lights up the little airbag symbol on the dash. I have been clearing the errors using the Inpa program which usually takes care of it for months.Yesterday, I was leaving a friend's house and that Dynamic Driving Malfunction error lit up my screen and rang the little audible alarm 10 times in a row. The car was weak in power and it was going nuts! After 5 minutes of driving, it settled down and everything seemed OK. I looked up the error codes using Inpa and got MANY including D35F, 5F78, FFFB, and 2F9A, I ended up unhooking the battery for a little while and tried it again. The car ran great and there were no errors showing on my dash. After 30 minutes of driving, the DDM error came back and there's 1 code showing in Inpa... 5F78.
I check my voltage at the battery while idling and it was 14.2 volts +/- .4 volts. When I turned the headlights on along with the air conditioner and wipers, the voltage dropped to around 12V while idling.
The car only has 10,000 miles on it. Why would this happen? My battery was new from BMW in 2013 and it seems to hold a charge OK. I'm wondering if my voltage regulator is bad or something. What does the 5F78 code mean?
Any ideas?
Thanks,
Randy
Any ideas?
Thanks,
Randy
My Ride: 2004 525i
Engine: M54
![Exclamation](https://5series.net/forums/images/icons/icon4.gif)
Hello everyone,
Any ideas?
Thanks,
Randy
Any ideas?
Thanks,
Randy
Hello, I know it's years later, and most are probably long passed this, but did you ever figure out what the issue(s) was/were? I'm having the same issues with my 2004 525i I continuously get the Passenger Restraint Error, increased emissions error, DDM error, and most recently the SOS call system malfunction.
I've been getting the passenger restraint error for years now and within the last year or so, I just chose to ignore it and have stopped clearing it altogether since it constantly comes back each time I start the car.
The increased emissions error I can clear and it will usually stay away for about 24-48 hours then it'll come back.
The DDM error only happens if I leave the shifter in "DS" mode for a long period of time. otherwise I don't see that pop up.
and the SOS call system malfunction comes up at the same time each time I start the car; roughly 60-90 seconds after starting the car it pops up.
I'm seriously hoping someone can direct me in the right direction, or just tell me what I need to replace so I can just do it. PLEASE!
Thank you!!!
Frenchy
My Ride: 530D Saloon
Hi Frenchy, have had the same error myself, 4 possible reasons:-
1. EGR valve clogged up with oil and gunge.
2. EGR controller not working.
3.Not achieving adequate coolant temperature ( > 88 degrees).
4.Leaking pressure tube connection from controller to EGR valve diaphragm.
Hope this helps
Hope this helps
Thank you!!!
Frenchy
My Ride: BMW 650i
Found this and wanted to share! There is actually a great blog post and YouTube video explaining this in detail. They even have a pre-trimmed version of the MOST adapter now that comes ready to install out of the box.
The stock version bypass/loop requires you to carefully hack away at the plastic to get it to fit. I actually damaged my first unit trying to get it to fit.
Anyhow, here's the link: https://www.modsandprojects.com/bmw-...o-audio-error/
