DVD+R readability problem
My Ride: 525d LCI - xenon, tv function,grey dakota leather,titanium silver,244 radial spokes.
I use the in-dash nav dvd player for my music. I burnt around 1.5gb of the 4.7gb DVD+R disc at first, all the songs showed up.
Now when I try and add new files to one of the folders or create a new folder/playlist it does not show up on the iDrive. Although the disc has been burnt properly as it's readable on my laptop and the newly added songs play perfectly.
How can i resolve this problem? I'm tired of burning new cds every time and find it easier to add songs to the dvd as and when needed.
Are you trying to use multi-session to add new files to the DVD? I don't think our drives like multi session discs. Try and burn a new DVD with all the old+new files and close the disc at the end and see what happens.
Yes, i think i did use multi session. Closing the disc will not solve the problem as I will not be able to add more tracks once done.
I want to be able to add tracks to the disc at a later stage too, looking for a solution to that.
My Ride: Sept '03 530d SE: Titanium Silver, Black Dakota Leather, Steptronic Auto, Bluetooth Telephone Prep, 6-Disc Changer, Business Navigation, Sports Suspension, Active Steering, Star Spoke 123 8Jx18" + Run Flat Tyres.
My Ride: E60 530d SE Saloon M57 3.0d, Deep Sea Blue, Anthracite Linea cloth
Z5K Visibility Package (522 Xenon Headlamps, 524 Adaptive Headlights, 502 Headlamp Washer System)
Z5P Media Package (609 Navigation−system Professional, 612 BMW ConnectedDrive−Assist, 616 BMW ConnectedDrive−Online, 620 Voice Control System, 633 Bluetooth phone prep + telematics, 672 BMW 6 Disc CD Changer)
300 Space−Saver Spare Wheel
465 Through Load System
610 Head−up Display
654 DAB digital radio
6FL USB/audio interface
The other option is to try DVD-RW; I use them successfully in the Nav system for speed cams as I also did not want to keep burning discs everytime a new speed camera database was published. I just erase and rewrite the disc - don't know if it will work for MP3 as I use a 16GB memory stick in the usb socket for all my music. Good luck.
In a multi-session the TOC is rewritten in another location and the car is designed to read the TOC only at the beginning so its ignoring all the other TOC versions. The DVD RW is a better solution because then you are effectively rewriting the entire disc again. But here again remember to do a full erase as opposed to a TOC (quick) erase because some systems don't like the left over data that is not overwritten from previous writes.
My Ride: G30 M550i
Model Year: 2018
![Cool](https://5series.net/forums/images/smilies/cool.gif)
Thanks for the replies!
Just got a DVD-RW to try if it resolves this.
@Nick: I have around 3.7gb to burn as of now, do I need to burn the entire disc the first time to enable admending later?
My Ride: G30 M550i
Model Year: 2018
When you're ready to update or change the contents of the RW disc, you'll need to erase it and re-burn it using the same, disc at once setting...
