DVD NAV making grinding type noise
Old Nov 25, 2004 | 04:28 PM
wassy's Avatar
anyone else have the same problem? with he NAV disk in, every now and again, usually about 20-30 seconds into the drive, and at various times throughout the drive, I hear a grinding type sound coming from the dash. I am positive it is the DVD player since it doesn't happen without the disc in it. The disc is perfectly flat. anybody else?
Old Nov 25, 2004 | 06:15 PM
soc_fans's Avatar
Originally Posted by wassy' date='Nov 25 2004, 08:28 PM
anyone else have the same problem? with he NAV disk in, every now and again, usually about 20-30 seconds into the drive, and at various times throughout the drive, I hear a grinding type sound coming from the dash. I am positive it is the DVD player since it doesn't happen without the disc in it.? The disc is perfectly flat.? anybody else?
[snapback]60921[/snapback]
Nothing is wrong with mine. You may go to the dealer and ask them.
Old Nov 25, 2004 | 07:20 PM
moballa's Avatar
Pay close attention to when the "grinding noise" happens...Not sure if your noise is like mine, but I notice a bit of "unusual" noise immediately when I cross city boundaries. I suspect the unusual noise is simply the DVD reader going crazy changing its data set to the new city you just entered. The noise I hear seems to die down after about 1 minute after entering a new city.
-Marco
Old Nov 26, 2004 | 02:20 AM
andy545's Avatar
Model Year: 2005
Engine: 545i
There's nothing wrong with it. The dvd-rom is just reading some new info from the disc. Mine does it as well occasionally.
Old Nov 26, 2004 | 10:30 AM
Iceman's Avatar
My Ride: F02 LCI Individual
Model Year: 2013
I here noises from my DVD very often, when the car is parked - before starting the engine or after shutting it down. Nothing wrong.
Old Nov 27, 2004 | 05:04 PM
alohalc's Avatar
[snapback]61099[/snapback]
you started sound like my dealer, noises = nothing wrong. my dealer said wiper rattles = normal .
Old Nov 27, 2004 | 05:09 PM
Iceman's Avatar
Model Year: 2013
No, I've seen your wipers in use... There is definately something wrong!
Old Nov 28, 2004 | 01:46 AM
alohalc's Avatar
[snapback]61430[/snapback]
believe it or not, i talked to my dealer about this and even the tech tested it out on his own and he promised to check on that. but by the end of the day, he said he tested three other e60 and they are all the same . i was pissed . even my service advisor and sales advisor said it doesn't seem normal but they couldn't do much since they are not the tech .
Old Nov 28, 2004 | 03:40 AM
530E60NL's Avatar
Mine does the grinding too.. I also notice my map stops moving when the grinding starts and when the grinding stops my map jumps to the correct posision.
Kasmo
May 7, 2019 03:30 AM
HeartofDavid
Apr 18, 2015 04:34 PM
derooster
Apr 16, 2015 05:53 PM
TreeTopFlyer
Feb 5, 2004 04:23 PM
