DTC
My Ride: 550i 2009 Mod. with tints all around. Got Splitter and Spoiler coming. May do an exhaust.
...I found maybe from right here! That when the DTC button is pressed for 2 or more seconds it appears the 4x4 feature goes into automatic ALL Wheel 4x4 and the instrument cluster shows an exclaimation mark [!] within a triangle and an outer circle and arrow head at about 10:00 on the clock. Its an interesting symbol if in fact it is for the full 4x4! I know I could have read the manual and maybe have asked my local BMW Show room with the fancy Keyboard activated Palsma TV which helps one get to know even the smallest of details, but I figure its always more fun to hear it first here. These rides are truely amazing! What goodies are in store for 2010 and the F-10?
My Ride: 2006 525XI, Jet black on Dakota beige. Premium and winter packages. I consider myself a purist and intend to keep my car absolutely stock and shiny.
2008 328I Convertible, Sapphire black on beige interior. Premium package, NAV, iPod adapter.
Retired: 2002 325I, Titanium silver on black leather. Premium package. Absolutely stock and proud of it.
No for some reason the instrument cluster at the top between the Miles per Hour and the RPM gauges shows a Triangle with and "!" and outer cirlce and when I press the "DTC" button for longer than 2 seconds the DTC 1st comes on then this symbol shows up. I can feel the car seemingly get very stout to the road almost like it is clawing at all fours? Go figure? Dan
Originally Posted by CCS' post='1052367' date='Nov 11 2009, 09:59 AM
I thought that by holding the button it just turned off DTC
My Ride: SOLD...Jet Black 2008 550i M Sport with SAT, black interior. RPI exhaust and air scoop, 35% huper optik tint all around, CF roundels, flat black kidneys, Springfield Armory XD-40 jet black in glove box, charcoal filter removed.
The way it works on my car is this: push the DTC for two seconds and the DSC is limited. push it in again for two seconds and the DTC is deactivated. The first two second push will get you a "DSC limited" or similar message on idrive and the second two second push gives you the symbol you mentioned and a "DTC deactivated" message on the idrive. There is no 4X4 function other than the x-drive.
Yes, this is on my 550i, but I've also owned a 330XI, and X-5 and my wife currently drives a 325XI.
hope this helps.
hope this helps.
Yeah DHA! My dealer Salesman said it gives you the Limited DSC Control that works as Ron says better with the more powered HP 5s. Is the DSC better in the twisties and corning? Thanks Dan
hope this helps.
hope this helps.
jeffandjaimie
Jul 8, 2015 05:48 PM
