DSC Lights up during acceleration
Old Dec 5, 2004 | 04:18 PM
johnmac's Avatar
I just started noticing that when I accelerate from a full stop the DSC warning lamp lights up briefly. This is the light with the ! inside a triangle with a circle around it. This happens almost all the time now and was not happening prior to me getting v13.3.
Is anyone else having this issue?
It also seems like there is quite a lag between when I pedal down on the accelerator and the car responds. Again, seems like this just started occurring since the upgrade.
(I apologize if this has been discussed in another thread - I tried searching but to no avail...)
-- JM
Old Dec 5, 2004 | 04:21 PM
Iceman's Avatar
My Ride: F02 LCI Individual
Model Year: 2013
Are you accelerating harder than before?
That ligt usually means the rear wheels lose traction and the DSC is active to prevent oversteering.
Does it also happen when you don't accelerate hard?
Old Dec 5, 2004 | 04:27 PM
johnmac's Avatar
[snapback]65199[/snapback]
Yes - it happens when I accelerate hard (but not like flooring it). Its become annoying to press the gas and have the car not respond, so I've been pressing harder, then I get the DSC lamp. Never recall seeing this prior to software upgrade... Can this be 'tuned' by a technician?
Thanks,
-- JM.
Old Dec 5, 2004 | 04:31 PM
Iceman's Avatar
Model Year: 2013
Well, the gas pedal response should be better after a software update. Mine was worse, but the update was not correct. So we updated the software again and everything was fine after that.
It is normal that the DSC kicks in when you accelerate hard. Accelerating harder is not helping you with the gas pedal response. I guess, if it is really that much worse than before (like it was on mine), your software should be updated again!
Old Dec 5, 2004 | 06:26 PM
realtyman's Avatar
My Ride: Now Driving a Freakin' Prius! Was... 2004 545i | SMG | White/Black | Sport | NAV | Logic 7 | PDC | Fold-down Seats | Adaptive Headlights | Cold Weather Pkg | Clear-again Bra | Mud Flaps | Bluetooth | Coat Hangar | Aux Input | All Weather Mats | 18"X8.5" BBS RK w/ Michelin Pilot Alpin's (winter) | New steering rack @ 1.2K & 17K miles| Software V.19.1 | B&B Exhaust (vrrrroooooommm!) <---Click.
How's the tread on your rear tires? Traction will decrease as the rear's wear down.
Old Dec 6, 2004 | 12:24 AM
colejl's Avatar
Originally Posted by realtyman' date='Dec 6 2004, 03:26 AM
How's the tread on your rear tires?? Traction will decrease as the rear's wear down.
Indeed. And which tyres? My 275's only lose traction when it's damp and you give it some welly
In the dry they're like glue
Old Dec 6, 2004 | 01:05 AM
heezy545i's Avatar
It's just a reminder to turn it off.
Old Dec 6, 2004 | 09:18 AM
Iceman's Avatar
Model Year: 2013
[snapback]65376[/snapback]
Only if you are experienced enough!
Old Dec 6, 2004 | 02:58 PM
johnmac's Avatar
My tires are brand new.
I'm more concerned about the lag than the light going on. Its seems like 1-2 seconds before the car responds to acceleration. Is this normal?
-- JM.
Old Dec 6, 2004 | 03:38 PM
The Pentium Guy's Avatar
Originally Posted by johnmac' date='Dec 6 2004, 06:58 PM
[quote name='heezy545i' date='Dec 6 2004, 04:05 AM']It's just a reminder to turn it off.
-- JM.
[snapback]65731[/snapback]
[/quote]
1-2 ! Jeez! this is something they NEED to fix!
chadillac2000
DIY: Do It Yourself
Apr 7, 2017 04:31 PM
TexaZ3
May 6, 2015 09:54 AM
Stranger12
Apr 5, 2015 10:42 AM
Bill109
Mar 15, 2015 10:53 AM
