Driving Lights/ DRL's/Pretty dumb question
My Ride: 2007 E60 550i Black/Sand. Dinan free flow intake, throttle body, carbon fiber strut brace, and exhaust. Carbon fiber engine cover. Blend mount for a Belltronics RD w/mirror tap. Smoke LED taillights. Projector fog-lites w/HID kit.
SO...... Pre-LCI... or LCI, what exactly am i driving?? or is this just a matter of coding?? little help here please.
You have pre-LCI ... the inner section of the headlight uses reflector while LCI has frosted lens covering it.
... plus LCI start as '08 model ... and then LCI tail lights has LED rods & blinkers.
OK, so im confused. Ive been believing i have a Pre-LCI BMW, a 2007 550i. Im confused because when i turn on my High Beams, I do this by pushing my turn signal lever forward and the high beams stay on, but its the outer "Bi-xenon" bulb doing this. However, when i flash oncomming traffic with my high beams momentarily, by pulling back on my turn signal lever and then releasing it, its the inner halogen bulbs that flash, not the "Bi-xenon" bulb. this set-up makes sense considering the rapid on/off of flashing would be more friendly to a halogen bulb than a HID Xenon bulb and ballast, no?
My Ride: 2008 Metallic Green 535i,Dakota Brown leather,NAV,HD Radio, Comfort Access,Sport pkg,Premium Pkg,Cold Weather pkg,Logic7,Park Distance, SAT/Paddles, Ipod adapter, tint, LED Side markers, & halos, heated fronts,CPO'd car, tinted tails, heads, reflectors, backup camera, afe cold air intake, led license plate lights, rear lip spoiler, recoded modules: remote folding of mirrors, deleted accept screen on idrive, auto unlocking of door when ignition turned off, closing windows, & sunroof w/ remote, digital speedo on instrument cluster.
My mistake. Sorry to confuse you, but you have pre-lci. Lci projectors have frosted lens that contains cornering lights, & clear fins on the sides where the turn signals are. Pre-lci has the inner clear lens with orange smooth sides where the turn signals are. Check this out: https://5series.net/info/2008_LCI_Detailed_Changes.pdf
ok, good to go, thats what i thought. i just upgraded my tail lights to lci tail lights, the fronts however i was really pretty ok with so i didnt really think of changing them out. i appreciate the feedback
My Ride: 2010 BMW 550i m sport lci
once you remove the headlight from the car to change the d1s bulb and you hAve those headlights that the projectors turn when you turn the steering wheel do i have to reprogram them or does the car do that on its own? thanx
Tsoup
15
12-20-2021 11:14 AM
srogers535x
14
04-26-2015 09:39 AM
