Drive control systems malfunction
My Ride: 2007 Mercedes CLS63 AMG
Designo Graphite with white leather interior
Keyless Go, Heated/Ventilated seats, Parktronic
While on my way back during a long roadtrip I got an error message on the idrive screen - "Driving Stability - Drive control systems malfunction. Reduced driving stability in curves. Drive moderately!" The error message goes away when I turn off the car but then comes back about 45 minutes later.
I'd like to just check the power steering fluid level but I can't seem to find the reservoir under the hood. Nothing is indicated in the manual as far as I can see. I've narrowed it down to the ATF reservoir, but isn't that Automatic Transmission Fluid, not steering fluid...right?
I called a BMW dealer and they just told my it's likely a sensor and not to be alarmed. I'm nowhere near a BMW dealer to have it looked at, so I'd like to just add a bit of power steering fluid to see if that's the answer.
Any suggestions
Any suggestions
I would also say it's a sensor problem.
Had a similar warning for the driver airbags - it was a sensor malfunctioning.
Awest91
09-17-2022 11:05 PM
TexaZ3
05-06-2015 09:54 AM
